Welcome back Brent!
Well if it's a 5spd and there's no compression across the board then it may have been money shifted, bad trans mounts and pulled wrong gear, would need a new head. Also very common is an overheat which will cause the head to warp a bit and also potentially crack, cylinders 4,5,6 would be low. Read the old "overheated" threads.
