Results 1 to 10 of 10
Thread: How can one perform recall software updates?
    Jan 2005
    Warner Robins, GA
    '69,'70 Mustang,'86 Bronco, '02 M3
    What program is used for software update? For example what is needed to perform voluntary recall 08E-A03 for cats below threshold on a vehicle without taking it to the dealer? Can it be done with ISTA-P? Thanks in advance.
    Ersin
    E46 M3 Ti Silver
    Dinam Stage I seat covers, ///M valve stem caps, ///M license plate frame and manual rear sunshade. Modified stock muffler.These are considered mods right?
    Jul 2004
    Houston, TX
    36 Cylinders
    I assume this is on the M3?
    For any E chassis, WinKFP is safer and better to use. ISTA-P and most K+DCAN cables (+newbie user) is a recipe for disaster.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jan 2005
    Warner Robins, GA
    Thanks 328,
    Yes this is for E46 M3. I have serial OBD and K+DCAN cables I use with INPA, DIS, ISTA-D for diagnostics and running tests, ISTA-P for coding new components (like new steering angle sensor). I believe I have NCS 4.5.3 and WinKFP 5.1.0 that I can install.
    My next question is, where can I find the file to update for 08E-A03, or how do I know if I have the right files for this update?
    Ersin
    E46 M3 Ti Silver
    Jul 2004
    Houston, TX
    36 Cylinders
    RealOEM says that ZB 7842343 is the latest for your car.
    BUT ZB 7842973 was released in March of 2009, and is the newest for MSS54 non HP DME, for manual M3.
    -Abel
    Jul 2004
    Houston, TX
    36 Cylinders
    Make sure your WinKFP configuration has "Fast Baudrate" unchecked (else it will brick your car model DME, specific to your car), and that UIF settings are checked.
    -Abel
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    Its actually best to leave UIF unchecked unless you need to change the UIF info(vin, etc). That way it doesnt plug up your programming count.
    There are e46 Daten files floating around as recent as 2014. Assuming the recall was issued before then.
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    Jul 2004
    Houston, TX
    36 Cylinders
    UIF slots are easily cleared, but it's a valid point. I like to see flash versions when diagnosing and tuning.
    I checked 2017 daten and nothing has been updated since 2009.
    -Abel
    Jan 2005
    Warner Robins, GA
    08E-A03 was issued in 2009 and I don't remember any SBs for manual transmission M3 DME after that. Now I have to find out if I have the right daten files. Thanks for the responses.
    Ersin
    E46 M3 Ti Silver
    Jan 2005
    Warner Robins, GA
    328,
    According to realoem, 12147842343 is for 2008 and up programmed DME. I can't find 7842973 in realoem, how did you know it was released in March 2009? Do you have an other source besides realoem?
    Ersin
    E46 M3 Ti Silver
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by aslanefe View Post
    328,
    http://www.m3forum.net/m3forum/showthread.php?t=423771
    -Abel
  1. Replies: 6
    Last Post: 01-07-2008, 12:48 PM
  2. how can one upgrade e38 01 740il cd nav to dvd
    By L1L RAJA in forum 1995 - 2001 (E38)
    Last Post: 08-10-2007, 12:17 AM
  3. How can one be SURE it's not (or is) a blown head gasket?
    By realjones in forum 1992 - 1999 M3 (E36)
    Last Post: 05-11-2007, 03:02 PM
  4. How can one tell when the rear shock mounts are bad?
    By scy in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-12-2003, 10:45 AM
