Results 1 to 25 of 29
Thread: At least the rust is gone, right?
    Oct 2015
    Washington, IL
    2003 540i6
    I noticed a rust spot last year and ignored it through the winter. This year it was much worse and really needed attention. Weekend paintjob!!! -more like a week due to humidity.
    It looked like there had been some work done here in the past.
    There was! A lot of pitting too.
    The black stuff is the rust neutralizer. I left it in all the pits.
    Looking good.
    Now to blast it with some prep spray!
    Oh no! I didn't read the can. The part where it says not to spray on paint that is less than 6 months old.
    Fixed! 2k clear is on!
    Oh, come on! Apparently, when you keep building layers of metallic paints, the color gradually gets darker.
    It's so ridiculous, it's kinda funny.. And here I was worried about orange peel. Oh well. It's staying on the car until next year.
    2003 540i/6
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Lawrenceville, GA
    4 BMWs.
    ???? That's nuts.
    tmaxx445's Avatar
    tmaxx445 is offline E38 6 Speed Club Member! BMW CCA Member
    Dec 2010
    Greensboro, NC
    '05 M3, '03 X5, '01 740i
    Good work, that was just the wrong color paint.
    2001 740i / S62 Swap / 6 Speed Swap / Titanium Silver Metallic / Grey Montana Leather / M Sport / Convenience Pkg / Heated Seats / PDC / MKIV Navigation / DSP / Bluetooth TCU / Dice Mediabridge / Vavona Trim / Illuminated ZHP Shift Knob / Short Shifter / Cat Delete / SAI Delete / Euro Tune / Koni Singles / H&R II Springs / Custom 3.15 25% Limited Slip Diff / Staggered OE M Parallels / 275 & 245 Firehawks / Euro City Lights / Celis Tail Lights / SunTek 70% CXP Tint
    2005 M3 Coupe
    / 6 Speed / Silver Gray Metallic / Black Nappa Leather / Premium Pkg / Cold Weather Pkg / Bi Xenons / Adjustable Bolsters / MKIV Navigation / Harman Kardon / Bluetooth / Sirius XM / Aux In / Carbon Trim / ZHP Shift Knob / Short Shifter / StreamLine Intake / SS Headers / AR20 Resonator / Exhaust Bypass Valve / P0lar Tune / Koni Yellows / Eibach Springs / Staggered OE CSLs / 275 & 245 595 Evos / Angel Eyes / CF CSL Splitters / SunTek 38% Carbon Tint
    2003 4.6is X5 / Stock /
    Oct 2015
    Washington, IL
    2003 540i6
    It was the correct color, but I applied way too much while trying to blend the lighter colored primer. I used the same paint last year on another repair and it was a perfect match. The difference was mostly the primer. The primer I used last time was a closer match to the base color, so I didn't need to use as much. I read that when you build metallic paint, it becomes darker. Unfortunately I masked off all my color reference points and had poor lighting. I imagine I would have caught it under ideal conditions.
    2003 540i/6
    Aug 2014
    Cheshire, CT
    1998 BMW 528i / 5
    Wow. That's incredible. What is the original color?
    Now you're gonna have to paint the other side to match!!
    Ed CT
    1998 528i
    5-Speed
    Aspen Silver
    Aubergine Leather
    Oct 2015
    Washington, IL
    2003 540i6
    Hahaha!
    Sterling Grey Metallic.
    I'm curious to see what it looks like when it's put back together. I'll post pics.
    2003 540i/6
    Lincoln Park, NJ
    2018 M3 6MT, 2001 740iL
    I dig the new color. How long to do the rest of the car
    Dec 2009
    Annapolis, MD, USA
    2012 JSW 2.5
    I just repainted the trim over my rear license plate and the instructions on the paint I used (www.automotivetouchup.com) were very specific about metallic paints. They said that, if you don't use multiple light coats and allow each coat to dry to the touch, the paint will go on too dark and the metallic flake won't look right. Based on my experience, they were absolutely right.
    [IMG][/IMG]
    Aug 2014
    Cheshire, CT
    1998 BMW 528i / 5
    Quote Originally Posted by JaxPlanet View Post
    Thanks for this, JaxP - good to know. I plan to do some touch up work. Not sure whether my code 339 Aspen Silver is a metallic (I don't see any flakes in it), but, I've always heard that multiple light coats are better than a big thick one.
    I wonder if Waters17 can, after the darker paint dries, apply a couple of light coats and get the color back to near normal...
    Ed CT
    1998 528i
    5-Speed
    Aspen Silver
    Aubergine Leather
    Lawrenceville, GA
    4 BMWs.
    Quote Originally Posted by Ed CT View Post
    It is metallic.
    Oct 2015
    Washington, IL
    2003 540i6
    Quote Originally Posted by agentrnge View Post
    Haha! It'll be a while. I'm still begging the e39 to let me save money so we can continue saving for a house. Once I have my own garage, I'll invest in proper painting supplies and spray the whole car. I really like the idea of a darker color. Sterling grey looks better out west.
    I concur.
    I suggest making sure your primer or base coat is as close to silver as possible. It'll be a lot easier to not go crazy with the spray. I found that I got so focused on laying an even coat that I didn't consider how much I was putting down. I also found that I started to get incredibly impatient.
    I could probably make it right, but I really don't want to right now. The rust was my main concern, this was just a.... minor setback.
    After I put everything back together, it doesn't look too bad. ಠ_ಠ It almost looks like the quarter panel is wet and the rest of the car is dry. I haven't seen it in full daylight yet though. I'll upload some pics tomorrow.
    2003 540i/6
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Just go pick some other colors and do this:
    Srsly didn't realize that about the metallics. I imagine its something about thin coats and full drying letting the flake settle out flat and reflective as opposed to being suspended at random angles or something.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Oct 2015
    Washington, IL
    2003 540i6
    LOL! I can't believe those were actually factory colors.
    2003 540i/6
    Lawrenceville, GA
    4 BMWs.
    Harlequin Golf! so much fun.
    Jan 2015
    Tempe, AZ
    1995 525i/5
    The Harlequin Golfs are quite rare at this point, a lot of people didn't really appreciate them when they were newer, so a lot of them have either gotten repainted or scrapped at this point. One guy who owns a VW shop in PA flew out to California to rescue a Harlequin from a junkyard, and it was quite an interesting adventure.
    1995 525i 5-speed - Thread
    Oct 2015
    Washington, IL
    2003 540i6
    I believe there's a reason they're rare.
    Here's a daylight pic.
    2003 540i/6
    Sep 2015
    Mankato, MN
    1999 540i
    Thick coat, Schmick coat! I can't believe that that is the right color.
    Mar 2017
    Lynchburg, VA
    2001 540i
    Whats going to be interesting is peoples reaction because the quality of the paint looks very good. Usually, you see something like that and it is clearly painted by a brain dead gerbil on meth. But yours is clearly a quality job, leading people to wonder why an otherwise competent seeming individual with an otherwise nice looking car did that. You should tell them its a thing now.
    2001 Salvage Title 540i
    My build thread: https://www.bimmerforums.com/forum/s...toive-decision
    Lincoln Park, NJ
    "oh yeah.. its factory. Yet another design cue that started on the e39 and was adopted by other manufacturers"
    Jul 2016
    Chicago, Illinois
    are slow
    Do it on the other quarter.
    Looks fresh af
    Oct 2015
    Washington, IL
    2003 540i6
    Quote Originally Posted by Mach540 View Post
    Here are some pics of a repair I did on the other side of the car using the same paint. The flat area at bottom of the fuel filler area had been previously filled with bondo and starting to bleed rust through. You can clearly see the cutoff line between the old paint and the new paint. You can also see where I got impatient right under the filler door. If you look, you can see an extra layer of paint that I left on there. I really need to work on my patience.
    Here, the entire inner corner had started to bubble in a similar way to the pic at the beginning of the post. Same paint.
    Quote Originally Posted by douglawrence42 View Post
    Thanks. I wish I had a polisher.
    Quote Originally Posted by XAlt View Post
    Looks fresh af
    Hahaha! Probably won't happen.
    2003 540i/6
    Oct 2015
    Washington, IL
    2003 540i6
    Silly update to the thread.
    I was screwing around in the garage last night, you know.. thinking bout stuff.. After I posted this thread, I wanted to just forget about the paint.
    I've learned some things in the last few years.
    1. check things before using them.
    2. see item 1...
    I had originally purchased a can of paint online and I fixed the things in the above post. A while later I bought another can so I could fix my quarter panel. All the results are above.
    Back to screwing around in the garage...
    I still have the 2 cans, so I decided to do a comparison.
    1st can (used for the filler door and the rear door) Looks pretty Sterling Grey to me.
    Second can (used on the quarter panel)
    So yeah, they sent me the wrong paint.
    Why do I insist on learning things the hard way???
    2003 540i/6
    Sonoma Whine Country
    E12, E12, E36, E39
    Quote Originally Posted by waters17 View Post
    Trust me, you're not the only one.
    98 328is
    02 525ita
    80 528i
    81 528ia
    and decades of owning and driving BMWs
    Aug 2014
    Cheshire, CT
    1998 BMW 528i / 5
    Occam's Razor proves true again. Maybe just a couple of light coats will do the trick.
    Last edited by Ed CT; 10-06-2019 at 08:47 PM. Reason: confused Truck-or-Treat with Trick-or-Treat
    Ed CT
    1998 528i
    5-Speed
    Aspen Silver
    Aubergine Leather
  1. X5 car wash disaster, (at least the 7 is safe :P)
    By CobraBytez in forum 1995 - 2001 (E38)
    Last Post: 08-12-2009, 10:39 PM
  2. at least the H1 is good for something
    By fast4d in forum Off-Topic
    Last Post: 06-18-2003, 02:46 AM
  3. Weights are back in (on?), the spare is gone...
    By Hugo in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-16-2002, 10:27 AM
  4. Fingers crossed I think the problem is gone
    By jagsm3 in forum Forced Induction
    Last Post: 06-21-2002, 05:15 PM
