I recall pics/diy were posted here....but now they are gone due to photo bucket crap.
I have a 99 28 coupe........
and I recall reading by unplugging this dew hickey our revs will no longer "hang up" between shifts....
Curious, I haven't ever heard of that. I wonder what.
But I do know some tricks in the tune that will cause some very nice engine rpm drop.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
-Abel
OP is talking about one of the clutch switch/sensors, I don't remember which. You'll have to go back about five years in forum dredging. As I recall, the side effects made this mod less useful.
/.randy
https://www.bimmerforums.com/forum/s...elay-on-M52TUs
You'll have to ask photobucket for the details.
/.randy
So there's a connection from the clutch switch to the MS42? Hmm, obviously that's how it does the cruise control control.
There has to be a method to do this with more finesse... to the MS42 tune!
-Abel
I have solved the rev hang between gear shift problem on a M52TUB25 engine by cleaning the idle control valve. It didn't make a sound with the ignition on 2 (should be able to hear it vibrating) and it didn't rattle when it was shaken when out of the car. Brake cleaner sorted it out and some CRC 5.56 was sprayed though it before reassembly.
1999 2.8L Z3 Roadster,
2000 3.0L Z3 Roadster,
To me bypassing the switch is not a fix; it's merely a kluge to hide the symptoms of the real problem (whatever it is). You end up disabling the clutch safety interlock for the cruise control and the starter. The later will not pass safety inspection in some states.
But I don't own a M52TU manual, so I have no way of doing long term testing.
/.randy
I did this mod to my clutch switch a few years ago, but can't remember the exact details, unfortunately. It was just a matter of jumping a wire to another pin on the connector. However, my cruise control works fine but I do have to be sure and engage the clutch before starting if in gear.
Lol. Having a manual transmission car in the USA is one of the best theft deterrents, or joy rides.
-Abel
I agree that it's not reasonable to disable the clutch safety switch--it is begging for someone to get hurt. There was a question posed in that thread in post #23 as follows:
and another suggestion in post #56:
And then there is the last post in that thread, #78, which, I think, clearly points to the problem with the initial idea:
to me.......just me
"I agree that it's not reasonable to disable the clutch safety switch--it is begging for someone to get hurt."
so what is the issue for you?
I couldnt care less about this......Im an ol skool guy....... get hurt?......not me.....and Im the only driver of said vee hickle
yup
I believe I just discovered the map in the tune that controls the clutch switch rev hang behavior.
No more cutting wires needed.
-Abel
Interestingly enough, in my Autologics, I can enable/disable the "auto-manual" function. This was an accidental discovery, as when going through the car's parameters, it was set to "auto"; well an M Rdstr certainly has a manual xmsn, so I set it to that!
It was at some later date that I discovered that I no longer had to depress the clutch pedal to engage the starter__trust me though, it's a habit to always put the car in neutral, because the Healey I've had for coming right up on forty (<40) years does not have that safety feature.
At the time, I thought maybe it was broke, but then I set my other car's parameter the same way, then it too no longer had to have the clutch in to start. One of those AHA! moments ensued. Once I had figured it out, I switched them both back to "auto" just in case my other half was to ever get caught out.
Of course, that only covers the starter function, but what is this rev hang of which you speak; do the Ms not have this (I haven't driven too many Z3s for any great distance or time)?
Ya, autologic needs to word it better.
BMW worded that coding as "auto/US Clutch switch" and manual (European mode) in the factory coding.
It will not make a difference on either of your M roadsters DMEs and programmed lag though.
-Abel
Wait, so on non-M's there is something making the RPM's hang a bit between shifts? Like a programming-based CDV?
PRICE CUT on ALL FABRICS
kinda sorta ....yup
-Abel
I just installed a copy of the code that Abel has been working on for this. It is still a work in progress, but initial testing shows promise that thru software changes the rpm spike during shift changes on my M54 3.0 can be reduced or eliminated. It makes shifting smoothly much easier, I am very happy with what he has done so far. I can't wait to see what it is like when he sorts it all out.
Jim
'16 BMW X5 3.5i
'15 GMC 2500
'01 550 Maranello
'01 BMW Z3 Coupe 3.0 manual 5sp
'97 Land Rover Defender 90
sounds good......pretty pretty good
