All of a sudden I cant set my clock and the cluster no longer has options when I hit the Button on the left stick I get nothing. Any ideas? Took cluster out to make sure plugs were set and all good
anything I need to do to check this so basically its just froze here is a pic. Oil light keeps flickering and oil is fine. Something is off.
Wiper fluid is low.
How old is the battery? These cars are rolling computers and whacky voltages cause whacky issues. PM scottjon. He’s the guru on these things.
Brand new Interstate and everything has been fine. I have a guy comming to look at it tomorrow to buy.
unplug the oil level sensor on the bottom of oil pan see if it goes back to normal.
Level 1 Certified BMW tech.
Check the cluster ground. The fact that you are getting flickering is a possible symptom of a weak ground. I believe it is one of the larger diameter brown wires in the large harness for the cluster.
