Results 1 to 6 of 6
Thread: No Intake Air Temp Sensor?
    Sep 2017
    Milledgeville, Ga
    2004 BMW 325I
    Question No Intake Air Temp Sensor?
    Hi guys! Looking for a little help. I am working my way through a couple of SES error codes mostly relating to my O2 sensors needing replacing. One of the codes that is also reporting is P0113 Intake Air Temp Sensor1 Circuit High Input. When I went to replace the sensor I found that there is no sensor there or wiring to go to it. There is a plug in the sensor's location that mimics the sensor's general shape down to O ring, but there is no real body to it and no electrical connection point. Is this normal on some 3-Series? Mine is a 2004 325I sedan.
    Any help would be greatly appreciated.
    Jul 2017
    42 deg lat -70 deg long
    Yes, please.
    I think that sensor is located center top of the m54 intake manifold.
    Sep 2017
    Milledgeville, Ga
    2004 BMW 325I
    Quote Originally Posted by Junglenut View Post
    Correct....that is where the "plug" was. There is also no wiring that I can find that would connect to the sensor that I placed where the "plug" was. The "plug" has the same general shape as the sensor (orienting side guide and click connector) but it is a blank...there is no post extending below the O ring and there is no electrical connections on top. When I looked at it when it was in place I thought the sensor was missing. All that I could see was the click connector, so I released it and pulled it out and the "plug" came out. It is not a broken piece. It was manufactured that way. Just curious if anyone has experienced that before, and if not where did my wiring go??
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    IAT sensor is part of the MAF. Early cars had a separate sensor. If your MAF has 5 wires then it's in there.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Osnabrock, ND
    2004 325xi,2004 545i SMG
    Quote Originally Posted by randy72877 View Post
    correct, the MAF sensor at the air box has the intake temp sensor built in.
    Level 1 Certified BMW tech.
    Oct 2012
    Charlotte, NC
    2000 323iT
    Exclamation Confirmation needed this can integrate with MS43 (mid-build)
    Hi guys, I'm in the middle of swapping an 04 ZHP engine (ms45)/exhaust into my M52TUB25 (ms42) wagon. I also just ran into this scenario with my donor engine. I'm going to be running ms43 - I have help that probably knows the programming but a vote of confidence from this recent experiment may save me a trip to the junkyard to pull a harness tomorrow.
  1. CODE 1224 :::: Intake Air Temp. Sensor ?
    By ///Arman in forum 1992 - 1999 M3 (E36)
    Last Post: 03-18-2017, 06:01 PM
  2. Replies: 0
    Last Post: 12-01-2005, 04:42 PM
  3. Part # for Intake air temp sensor?
    By Doc325i in forum 1991 - 1999 (E36)
    Last Post: 10-26-2004, 05:59 PM
  4. What is intake air temp sensor?
    By LUIS in forum 1992 - 1999 M3 (E36)
    Last Post: 08-05-2003, 04:01 PM
  5. Need help finding Intake Air Temp. Sensor
    By dbruce in forum 1992 - 1999 M3 (E36)
    Last Post: 05-19-2001, 04:52 AM
