Hello!
Bmw 320d xDrive -09 (xenon original) (european model)
So, im basicly out of ideas right now, so im turning to you guys.
The case is, i bought a pair of RGB h8 angeleyes and installed them and it turns out theyr flickering in all light settings except when only "parking lights" are on, then they lights up brighter and the flickering stops.
So ive tried to disable the angel eyes (h8 socket, halogen original now RGB LED) for 2 dags straight now but no results.
I use ncs expert, ncs dummy and inpa (still cant find a way)
So i need somehelp with:
Turn off the angel eyes( inner h8 halogen light (now RGB led) in all light settings including Auto and the third step from left(?) and ONLY be able to have them on in parking light setting.
What and how to code it?
And if someone know how to code the turning indicators to be on all the time like the US version, please tell me what to change (i got the european model)
Sorry for my english, hope you can help me
Ask if you have any questions.
Kind regards.
Provided the bulbs you purchased are CAN Bus compliant, all you should need to do is to disable the cold bulb check using NCS to stop the flickering (which is caused by a small voltage being sent to the bulbs by the car in order to verify that they are working - this voltage is low, so is generally insufficient to illuminate conventional bulbs, but LED bulbs will flicker). If the bulbs you purchased are not CAN compliant, you have 2 choices - fit them with an appropriately sized ballast resistor or buy CAN compliant bulbs.
