Results 1 to 8 of 8
Thread: ECS Tuning Bronze Caliper Guide Bushing Install Issue
    Jun 2017
    Cleveland, OH
    1998 M3 Coupe
    These bushings came with the car when I purchased it, new in box. This is the first time they are being installed. I am trying to install them on a new set of calipers. My question lies in the rubber o-ring that you have to insert inside the bushing. Once I insert the ring, the guide pins provided no longer have clearance to slide through the bushing. It is a complete blockage and grease/lube made no difference. Has anyone had this issue?
    Oct 2003
    Seattle
    99 M3
    I've not installed these, however it appears there needs to be grease on the o-ring and guide pin. Then thread the guide pin into the o-ring and probably tap the pin in the remaining distance.
    Could remove the o-ring from bushing.
    I have had to "ream" or "hone" caliper bushing bore to get them to fit without binding.
    I used a strip of emery paper in a very large cotter pin in a drill motor to "hone" the bushings till the caliper slides freely on the pins.
    In your case I would remove the o-ring and test fit the caliper/pins and 'adjust' the Bushings as required.
    I have seen the results of caliper bind and you don't want to go there.
    http://enews.ecstuning.com/q/MCLXY-K...sUQrzUv3-tFkgg
    Jun 2017
    Cleveland, OH
    1998 M3 Coupe
    Quote Originally Posted by bluptgm3 View Post
    I've not installed these, however it appears the o-ring needs to grease the o-ring and guide pin. The thread the guide pin into the o-ring sand probably tap the pin in the remaining distance.
    I have had to "ream" or "hone" caliper Bushings to get them to fit without binding. I used a strip of emery paper in a very large cotter pin in a drill motor to "hone" the bushings till the caliper slides freely on the pins.
    All of the pins slide freely in the bushings without the rubber rings installed. I tried grease but there is still a blockage and zero clearance to push them through. It doesn’t feel like a binding due to close tolerances.
    Oct 2005
    Auckland, New Zealand
    BMW 97 M3 3.2 Euro
    Interesting S50B32 just uses the pins. No bronze bushing.
    Aug 2013
    1999 BMW M3 Coupe
    I have these bushings.
    Yes, the O-rings stick out a bit to far and make it difficult for the guide pin to get past at first. Just force the pins through a few times, either by screwing them into the caliper carriers or by tapping/pressing them through by hand, and it'll grind off the excess o-ring material and move freely enough. Once you can slide them through by hand, clean up the rubber debris on the pin and inside the bore, grease it up, and you should be good to go. I discovered this through trial and error after being confused as to what it was binding up on while trying to screw them in the first time. I just had several hours on the track with mine a couple weeks ago with zero issues.
    For grease, I'd suggest a light coating of copper anti-seize as it seems that's what most people use on these, though any high-temp grease should work.
    Oh, and make sure you regularly pull the guide pins to clean and re-grease them and the bushings. If it's a street car, at least as often as you change the oil. If it sees the track, clean them before every track day as well. You don't want one of these to seize.
    Jun 2017
    Cleveland, OH
    1998 M3 Coupe
    I ended up not using the o-rings. It’s a track car so I plan on cleaning the pins regularly anyways.
    Oct 2003
    Seattle
    99 M3
    American Grease Stick Co. Sil-Glyde Silicone Brake Lubricant
    Wadsworth, Ohio
    BMW
    As TostitoBandito said, they are a SUPER tight fit with the o rings in place. On my car it took a ton of fidgeting to get everything set up with the o rings/seals/etc.
    -James
  1. :: ECS Tuning :: Introducing the ECS Performance Caliper Guide Bushings
    By ECSTuning in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 10-02-2017, 04:12 PM
  2. Brass caliper guide bushings from Turner or Bavauto
    By bmwpower in forum 1988 - 1996 (E34)
    Last Post: 06-02-2008, 05:04 PM
  3. Brake question?? (bronze caliper guide bushings)
    By Walechamp in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-07-2007, 11:32 PM
  4. Need help installing turner brass caliper guide bushings *pics*
    By jworms in forum 1992 - 1999 M3 (E36)
    Last Post: 06-14-2006, 10:15 PM
  5. Solid Caliper Guide Bushings
    By rcs328 in forum 1991 - 1999 (E36)
    Last Post: 06-17-2005, 01:37 PM
