Results 1 to 6 of 6
Thread: Electric issue in fuel pump circuit!
    Sep 2017
    Michigan
    BMW 740IL
    Hey guys, this is my first post on here and I've been using this site for help my entire way through this project but at this point I'm not even sure what to search on here because I'm so lost. I'm working on my girlfriends car ever since it died on her because of a bad alternator. It has always had a rough idle. I replaced the alternator no problem (thanks to a thread on here) and then when I went to start it I could keep it running I found it to be low fuel pressure. I check all the fuses and relays and everything was working. I went to the fuel pump and took it out and tested it by jumping it. It works perfectly fine. Then I checked the power at the connector for the fuel pump and I only have power to my fluid level sensor, not the pump. Then I went back to check the fuse and relays and I have no connection at the fuses under the hood! I have no idea what is going on or where to even go from here. Any ideas? Thanks for the help!
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The fuel pump only gets power for a short burst when the ignition is switched ON initially, and then will do nothing until the engine is turning (either running or cranking) - so don't worry if you can't find power on the pump without the engine running.
    My BMW Repair YouTube Channel
    Sep 2017
    Michigan
    BMW 740IL
    Even when cranking the engine, I have no power at the pump
    Feb 2009
    KC North, MO, USA
    1996 740iL
    DME sends power to the relay, in the trunk, while engine is cranking IF it's getting the needed signal from the crank position sensor. That particular sensor does not always throw a code when it's bad. If you have a VOM, check the ohms. Should be around 550 between pins 1 and 2. If will be way off or zero is it's bad. Bosch only if you have to replace it.
    Aug 2015
    Stockton, Calif.
    1999 740Il,1999 Corvette
    I don't know the proximity of the crank sensor to the alternator mounting, but replacing it maybe unplugged it?
    Feb 2009
    KC North, MO, USA
    1996 740iL
    B6203, X6203
    on RH side of transmission
    B6203 Crankshaft position/RPM sensor
    X6203 Component connector (3 -pin, Black), Crankshaft position/RPM sensor
  1. Electrical Issue 2 (Fuel Pump Relay)
    By aezplcc in forum 1991 - 1999 (E36)
    Last Post: 10-04-2010, 04:09 PM
  2. Weird electrical issues in cold weather
    By v8E34 in forum 1988 - 1996 (E34)
    Last Post: 10-18-2009, 06:36 PM
  3. 3 Electrical Issues in one day
    By msimp227 in forum 1995 - 2001 (E38)
    Last Post: 08-05-2008, 09:17 PM
  4. New owner, electrical issue - temp/fuel guages
    By Evergreen320 in forum 1975 - 1983 (E21)
    Last Post: 05-27-2008, 10:57 AM
  5. Electrical Issues in 03 X5's?
    By MCM97 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 06-14-2007, 11:54 AM
