Bad designs? How about aircraft? I spent years working on the A10-A Warthog that had its design issues. Oh, I forgot about the various F-4's I had the pleasure of crewing back in the day. And there's the F-111, that aircraft took over an hour to launch. F-16, and its hydrazine apu? Yikes! I don't worry too much about bad designs in things that don't fly
Tony
"You can't sign away negligence."
Adding this hurricane Harvey restoration to the collection.
328d in need of some love. It's up and running, some minor things left and will be a secondary daily, and roadtrip car.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
Short quick version: I bought it sight unseen from Houston insurance auctions, flooded car from Harvey. The intent is to restore it and have an experiment car, tuning/power, manual conversion, 2wd conversion. A car to beat on and put miles. Inexpensive.
I had been following a few 328d's to see if they may become worth it. And strangely enough the wagon (which I now love) was cheaper than the couple sedans I was following. I wanted a sedan originally.. and this wagon fell in my lap. Scary notion because I didn't have much to go by, just a few pics. Ideally you go and visit the car.
Picked up this week Monday. Way better than expected interior, and someone seemed to have vacuumed it out right after flood. It must have been in slow moving water because it was clean, non-muddy fresh water.
Oil was clean, air filter clean and dry.
This is what the interior looked like at pickup:
It had traces of water inside, 2-5inches in front, rear maybe 6-8. BMW seems to have wisened up and had very few modules down low... so most was spared actually.
I have replaced some major modules, and will be replacing a couple more. Pulling interior and shampooing what can be washed, replacing what doesn't look good.
Tuesday and Wednesday I refreshed, cleaned, and protected all major power connections, new battery, new rear fusebox. Thursday I spun engine by hand, all good. Hit start button, and it started immediately.
Today I drove it for the first time. After the short drive, it still only had 6 errors. 3 for the seats (seat modules getting replaced), 1 for def fluid low, and 2 for my disconnected telephone module.
Moving in the right direction with it.
Can't seem to want to sell any of the other cars.
-Abel
Sounds like the deal of a lifetime - 328d wagons command a premium around here - I have seen a few used for sale but they are still 30k+. Interesting you are doing 2wd conversion - and a manual conversion!? Wow true unicorn - Good luck, and keep us posted on progress.
“Great wisdom is generous; petty wisdom is contentious.” 无为
On this car, full 2wd conversion is a simpler process (compared to E90) of removing front driveshaft from the transfer case, removing front diff, and pulling the 2 front axles.
Then some car coding magic, to make all other modules think it is 2wd. I only really want to do it if it will improve mpg by some amount. I will probably experiment with unplugging transfer case and 2wd coding to see if it will make any difference, before pulling hardware out.
Manual conversion will need the manual transmission from E90/F30 Euro 320d, with shifter parts, driveshaft, and pedals. I have a few contacts in europe that may find me what I need. The rear diff gearing is 2.81 on this car; the Euro manual is 2.93. So no change needed there.
-Abel
It seems there's an E12 or E28 (don't know which one) available for R25k ($1824). Too bad I don't have the cash. If I can get a nice E12 (and aparrently this one is very nice) and have the cash I'll buy it immediately.
1999 BMW Z3 2.8 Roadster - show project
1970 VW 411L Auto - show/restoration project (sold)
1982 BMW 518i E12/8 - stolen
1987 Mazda 323 1.5 SL - daily driver, backup show car
- 1of1 rebuild (build thread) -
- Wanted Car items - FS: PnP aftermarket alarm details -
- Coupe Custom Subwoofer box - FS: Z3 Coupe LED 3rd brake lights -My Website for DIY content and parts: Double Bee Garage
'98 RMS stage 2+++++(491whp/390tq VAC cams, CES Cutring-9:1, Built blower, Meth etc)
'09 Saab 9-5 Combi 5mt 1 of 1(Built Motor, Brembos, LSD, the works!)
'22 Cadillac CT4-V BlackWing 6mt
'22 Cadillac CT4 2.0T Sport AWD (wife's)
This thread makes me feel bad for not having an mcoupe yet. They're still my dream car, and they've only gone up in value since I've wanted one. Here's two of my other cars, an Esprit and a 928.
Small (?) update:
racecar!
All lower interior is out. All carpets getting shampooed, all wiring checks out, disconnected and protected everything.
*get this*... BMW put ZERO sensors under the carpet of this car. All splices are corrosion proof, and important connectors are water proof/sealed.
The quality and the well thought out design is impressive. I didn't think I'd say that... Maybe it's not true of higher series, but the F30/F31 is not all that bad. But I suppose it depends what options it comes with too.
Wife had a blast pulling the center console (with workshop documents help ), while I pulled the seats.
So far I have about $400 in new AGM battery and a couple of modules that I chose to replace. And I will probably put another $600 in maintenance and little bits and pieces.
-Abel
I guess I can list some of the cars I currently own, but the list is pretty long.
'99 M Coupe
'99 2.8 Coupe (semi-project)
'03 Mini Cooper S
'86 Vw Vanagon syncro (powered by 2.7 Suby flat 6)
'80 Triumph TR8
'62 Healey 3000 tri-carb
projects in the garage;
'70 TVR Vixen 289
'70 Marcos GT
'64 Jag XKE 3.8 coupe
'66 Chevelle SS cvt
'73 Land Rover/Defender 90 hybrid
'69 Beetle cvt
'66 CJ5 V6
in storage;
'74 BMW 2002 (nice original Inka paint, bought new by my mom!)
'57 BMW R69
(2) '72 Norton Commando Combat
'69 Royal Enfield Interceptor
'76 Ducati 900GTS
'76 Triumph 750 Bonneville
'83 VW Scirocco (bought new)
'60 Willys Sedan Delivery
'62 Willys FC150
'65 Corvair Corsa cvt
-Donny
Wow. Where do you find space for all of that?
jag coupe.....lets see it
damn donny damn
I thought I had a picture of the Jeep hood, but can't find it now.
04R 3l 6 sp VF SC, custom ducting, alphaN, 2.62 pulley, multiport WMI,Severn Tuning(Pokeybritches), Tial BPV,Ceramic header, magnaflow section 1, SS race muffler/y-pipe, megan mounts,42 design catch can, CDV delete ,custom strut bar,3.91 LSD, H&R bars, Hotchkis links.Eibach Pro Kit,Koni Yellows.Megan camber arms. Carbon interior,SSK,UUC lines.CF aero. Poly bushings.
I've seen the TR-8! Me want. And bits of the 2.8. Oh, and the M Coupe often, but not recently....
Stuff. I got stuff.
Some neat engineering for sure. Actually pretty roomy and 51 mpg so far. If asked, I say I drive a Z!
Update time:
I washed and dried the carpets and other panels that needed to be cleaned. Worked real well with laundry detergent (Tide Original), and lots of scrubbing and rinsing.
Here is the car being worked on (my wife in the back) a bit more inside my dad's machine shop/my storage place, refreshing the final details before putting the interior inside.
I finally had a chance to use the lift to flush all drivetrain fluids.
Yummy transfer case whipped cream
Rear diff had a little bit of water, transfer case had a lot more, front diff negligible. Transmission and engine oil were clean. I flushed rear diff (and drove car in air) 4-5 times with cheap gear oil and put Redline 75w-90 as final. Transfer case got flushed 8-9 times and received BMW DTF1 fluid. Front diff was drained and received Redline 75w-90.
Transmission service kit coming in with new fluid and filter soon.
I have replaced anything that was even remotely touched by water, to prevent any issues in the future. Anything needing programming/coding, I will do myself.
Wiring is good, no signs of damage at all. It has all been cleaned and spray protected.
Parts list so far:
-rear fusebox (dealer new, $126)
-H7 AGM battery (local parts store, plus discounts and rewards points, $119.99)
-passenger seat heating module (ebay used $34)
-driver’s seat module (ebay used $58)
-telematics module (optional, ebay used $53)
-amplifier (ebay used $75)
-FEM, front electronics module: has EWS, security, body control, light control modules, gateway all consolidated into 1, (ebay used $55, + $100 data cloning procedure by a forum member)
-tailgate latch, (ebay used $75)
-ZF 8HP transmission oil pan with bolts, plus 7 liters of LiquiMoly 8HP fluid ($172)
Went to the dealer and picked up driver's door handle grip rubber ($60), as it was melty from PO using hand lotion, very common.
(Coincidentally and ironically, this dealer visit got me a job in clinical research, exactly what I need for my career.)
I broke the throttle pedal connector end on the wiring to the pedal while disconnecting it..
So I also bought a new connector part number 61138383300 ($3); disassembled and de-pinned the old one, and re-pinned it into new connector.
Progress is good. I filled the DEF and the "729 miles to no start" error cleared.
I am starting to learn how to tune this ecu (Bosch DDE701, actually an EDC17C50), I have read the ECU memory and begun sorting out the maps necessary for more power, while saving efficiency. I have some excellent support and information from contacts, so this will be fun as well.
Briefly looking through things, this car is capable of around 220whp and some 380ft-lbs of torque with stock hardware. (Dinan dynoed the 328d and got 194hp and 297ft-lbs torque, a bit more over official numbers)
A mild tune of +20-25 hp and +50ft-lbs is easy, but pushing the last 20-30hp will require some rescaling and expanding of maps.
-Abel
Awesome work on that wagon!
PRICE CUT on ALL FABRICS
