e46
Use would be dedicated track car . I assume i'd have to do subframe inspection and probable reenforcement , suspension is probably toast .
If I decided to put in a newer motor , would I need anything different over an e36 (I've been part of 2 e36 motor installs so far) , can I reuse the DME , just need the motor ? Are all e46 harnesses the same between 330 / 328 / 325 ? (I know the M3 is different)
'92 325is
'17 Mustang GT for a Daily
What is e47?
Type of what?
I would not buy an E46 with those miles regardless of what it was to be used for. Remember, everything on the car has seen 334k miles. Every plastic part, every bolt, every screw, everything.
A dedicated track car? Absolutely but price would have to be less than $1000. Making it into a track car is no weekend project. Do all the proper reinforcements and you should have a fun toy
no the e36 motor is not the same, and wont work in an E46 without way more work then its worth.
330k miles is super high, Even if the car is free it still seems like a bad idea considering it needs a motor. If you are just looking for a track car why not look at salvage ones? You can pick up pretty decent e46 with much lower K for less then $1000. If you dont care about the title then its super easy.
I just bought a 330 5 speed with 140k miles for $570 at salvage auction. One window is broken and the car was key'd all over. I needed it for the driveline, but would of made a great track car.
Current:
- 09 335i MSport, FBO.
- 98 Euro M3, Estoril Blue
- 04 M3, Carbon Black, 6 Speed Coupe
- 06 M5, Black on Black, Full Leather.
- 73 3.0CS, Tagia Green, 5 speed M30b35 converted
Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
'92 325is
I bought my e46 pre "key'd" too. Good thing im not to fussy about scratches on the paint.
Current:
