Results 1 to 5 of 5
Thread: BMW Scanner 1.4 "unlocked version"
    Aug 2008
    Norway
    Automobile
    I have a question about the BMW Scanner 1.4 "unlocked version". Does anyone know if that spesific version can also write a memblock file to an ecu eeprom chip. It does list it can read and save one, but cant find if it can write one
    BMW e39 523ia Touring 04/2000
    BMW e39 528ia Sedan 01/2000
    Jul 2004
    Houston, TX
    36 Cylinders
    M35080 eeprom can't be erased/written by PASoft or any other software through diagnostics K-Line. You have to read it and write it with a direct eeprom reader.
    It will not have anything to do with PASoft lock/unlock.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Aug 2008
    Norway
    Automobile
    Isn't this vid showing that its possible with PA Soft? But if so i guess its only the mrsz4 and some of the mrsz3's
    https://youtu.be/0puup1pTbsA
    Jul 2004
    Houston, TX
    36 Cylinders
    I jumped too quickly to conclusion that you were trying to read/write an EEPROM from an instrument cluster or such.
    Same situation applies for airbag, but you would be reading the MCU internal memory.
    Many tools can read the memory, even INPA can, but you cannot write to some while it's powered up and processing.
    -Abel
    Aug 2008
    Norway
    Automobile
    Yes, BmW scanner could be used to clear the eeprom, but unfortunately cause of the interface i cant use it on the airbag module i have cause its onboard write only. Btw heard that its possible to swap out the mrsz3 with mrsz4 if only changing the impact sensors?
  1. BMW Scanner help. Need to unlock EWS 3.
    By vampofvegas in forum Diagnostic Software
    Last Post: 03-03-2017, 12:41 PM
  2. BMW Scanner E6x version 2.1.0
    By PAPER in forum Diagnostic Software
    Last Post: 06-17-2015, 07:32 AM
  3. BMW scanner version 1.4.0
    By mandito219 in forum 1996 - 2003 (E39)
    Last Post: 02-13-2013, 10:56 PM
  4. BMW Scanner Version 1.4?
    By hwong in forum Canada
    Last Post: 05-11-2012, 01:31 PM
  5. BMW has NO plans for hatch version of 1 series for the US
    By mpower00 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-23-2004, 09:52 PM
