Results 1 to 24 of 24
Thread: The joys of vacuum leaks
    Jun 2017
    Denver, CO
    325xi; 740i
    Does anyone know what the size is and the length of the vacuum hose to the brake booster? Any tips and tricks taking the intake manifold off? I'm leaking from my throttle body and rear PCV and the brake booster vacuum is torn right at the end. What's the cold idle on the M60, I would imagine 1k give or take but I've never seen mine above 500 and turning the AC on smoothes out the idle and only raises 30 rpm sometimes.
    Jul 2016
    Chicago, Illinois
    are slow
    You don't have to lift the manifold to remove the PCV, replace it with the M62 type.
    Jun 2017
    Denver, CO
    325xi; 740i
    What about the vacuum line to the brake booster? I just figured that if both throttle plate and pcv are leaking the manifold itself probably is too or will shortly.
    Jun 2017
    Denver, CO
    325xi; 740i
    What would be the benefit to using the PCV plate from the M62?
    Oct 2007
    Boca Raton, Florida
    89'750iL,98'740iL,00'M5
    Is the hose you are looking for #6 on this page?
    http://www.realoem.com/bmw/enUS/show...diagId=34_1870
    BMW 7er Website www.7er.com
    1989 BMW 735i Schwarz (sadly, sold) // 1989 BMW 750iL Cirrusblau Metallic // 1998 BMW 740iL Oxfordgrün Metallic // 2000 M5 Carbon Schwarz ///
    Jun 2017
    Denver, CO
    325xi; 740i
    I think number 7, it goes from the booster being a plastic line to just about the intake manifold where it switches to a rubber one.
    Oct 2007
    Boca Raton, Florida
    FCP has them online for $6 and change. If you give me the vin of your car I can confirm the right part number depending on build year, but I put in early 1994 and so that part number should be correct. Copy and paste in google or FCP/Autohausaz etc.
    Jul 2016
    Chicago, Illinois
    are slow
    Quote Originally Posted by yukon101 View Post
    Slightly improved
    Jun 2017
    Denver, CO
    325xi; 740i
    It looked correct, the build date was November of 93 for the 94 year. It looks like you have to remove the manifold to replace it, is that correct?
    Jul 2016
    Chicago, Illinois
    are slow
    No it's screwed in, usually torx/ribe.
    Might have to get the expansion tank out of the way.
    Jun 2017
    Denver, CO
    325xi; 740i
    Quote Originally Posted by XAlt View Post
    Oh okay. I was originally trying asking about the break booster vacuum but I couldn't figure out how to quote from the phone version.
    Jun 2017
    Denver, CO
    325xi; 740i
    I have the new part now, I can unscrew the clamp to one side but what about the other is it clamped on too forcing me to remove the TB?
    Oct 2007
    Boca Raton, Florida
    Can you send a photo, im trying to envision what it looks where you are having the issue.
    Jun 2017
    Denver, CO
    325xi; 740i
    The cracked one on the left is the one going to the brake booster to which I have a replacement but unsure of how to replace it.
    Oct 2007
    Boca Raton, Florida
    Look to see if you find that hose at the back end of the engine near the firewall. In my E38 the booster has a hose from it to the PCV in the back of the intake. This may be the case here as well on the M60 which is very similar to the M62.
    Jun 2017
    Denver, CO
    325xi; 740i
    I have a new M60 PCV in hand too and it has two connections for vacuum so brake booster and fuel pressure.
    Jun 2017
    Denver, CO
    325xi; 740i
    Would I be able to cheat and replace just the elbow by taking the TB off? I also do have vacuum leaks for sure, I unplugged the ICV and it idled even lower than it does nearly to stall and unplugging the MAF had no change at all but the in and out of limp mode made my trans shift even better.
    Oct 2007
    Boca Raton, Florida
    Thats where I am losing you, I cant find a good layout of the engine bay and vacuum lines for your M60. Someone else may have to chime in. Wish I saw this before I went to the junkyard, there was a 740il E32 there that I could have referenced.
    So that line that is cracked, does it not extend down to the back drivers side of the engine to the PCV?
    Jun 2017
    Denver, CO
    325xi; 740i
    Unless I ordered the wrong part it would be just that elbow that is cracked as its only a rubber elbow maybe 4 inches long, it does go back to the rear PCV.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Besides the drawings in realoem check also the workshop manual if there are some -although bad quality - drawings https://www.bmwtechinfo.com/repair/main/481en/index.htm
    M60 engine bay details I do not that much.
    Jun 2017
    Denver, CO
    325xi; 740i
    I felt I should drop by and give a quick update, it turns out the brake booster pulls it's vacuum from the bottom of the throttle body and only the FPR pulls it's vacuum from the rear on the M60.
    Jun 2017
    Denver, CO
    325xi; 740i
    I went to remove the horrible bolts to find they haven't been touched in 26 years and immediately stripped, I grabbed the vice grips and not even they could get it removed no matter how tight I made them. Any idea what I should do? I am 99% sure the rear PCV is the same way and miraculously isn't cracked or broken in any way.
    New Daily:
    2011 Audi A6 Avant 3.0T prestige. 1 of 368
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    94' BMW 740i 308k miles
    Fresh 72k mile engine with all new seals. True E34 Manual Trans Engine Harness. 6spd Transmission Swap, Getrag 420G. RHD LW Single Mass Flywheel. E39 M5 Clutch. E39 M5 Shifter. Factory Car Phone. Factory 6CD Changer. Factory Electric Sunshade. Not So Factory Factory Electric/Heated Rear Seats. E38 Heater Valves. E43 M5 calipers/brakes
    Sold:
    1996 Oldsmobile Aurora; 194k miles but with a bad paint job and dented fender resulting in a payout to buy the 740i
    Jan 2005
    Japan
    Try a Screw Extractor, removes snapped off bolt from engine https://www.youtube.com/watch?v=mRGcuGK-POs
    Jun 2017
    Denver, CO
    325xi; 740i
    Being this is now the case and not being able to remove the rear PCV, does anyone know if it just removes like a normal V8 manifold with it all together still or does something need to happen first.
  1. Please confirm diagnosis of vacuum leak...
    By pangris in forum 1991 - 1999 (E36)
    Last Post: 07-17-2004, 01:14 PM
  2. The joys of a new bearing
    By Rexversusu in forum 1983 - 1991 (E30)
    Last Post: 03-27-2003, 01:50 AM
  3. Ahhh... the "joys" of Living In California
    By iamane30m20nut in forum Off-Topic
    Last Post: 01-03-2003, 11:58 AM
  4. The joys of owning an M3
    By tb0ne in forum 1992 - 1999 M3 (E36)
    Last Post: 07-08-2002, 10:41 PM
