Results 1 to 7 of 7
Thread: Bcables silver cable.....
    Aug 2015
    Cologne, MN
    03 M3 00 740i 98 528i
    I can get it to work for K CAN cars (95-07) but for the life of me will not connect to a 08 328xi I'm currently working on. 10/07 production date, but 08 model year. Won't connect VIA K CAN with any software (currently using Reingold ista d/p 3.54 I think it is), D CAN senses no vehicle.
    I'm using a bcables silver cable, which is supposed to support both K and D CAN work. My question is, is my cable built correctly? I know there's something about bridging pins 7&8, which are not bridged/switched on my cable. Instead, 8 goes straight to the circuit board inside the plug, and pins 1&2 are wired to be switched for K/D CAN. Is this correct? Or did I get a 5 o'clock Friday/8 o'clock Monday cable?
    Thanks for any/all input!
    Last edited by MN2K740i; 09-19-2017 at 11:02 AM. Reason: Apparently I need a new photo hosting service....
    2000 740i - 149K - Dville Monsoon rear deck speaker upgrade, GROM audio Bluetooth
    1998 528i - 204K - GROM audio Bluetooth setup, Drilled/Slotted Rotors, BSW Stage One speaker kit, Facelift Xenon's with Angel Eyes
    2003 M3 - 210K - BMW Euro Cross Drilled Rotors
    Dec 2012
    North Carolina
    2009 335i M-Sport Coupe
    Cars built after 03/07 are D-CAN. If your cable works on K-line, pins 7+8 are bridged somehow. D-CAN requires that the pins remain separate. If there is no jumper wire, perhaps your cable mode needs to be switched with a software utility.
    Aug 2015
    Cologne, MN
    There is a D CAN utility with the cable, but no matter the switch position and software setup, it just won't connect at all. Here's how this cable is configured internally.....I'm almost tempted to just say screw it and get the Reingold tablet and be done with it all being that at that point, at least I know that will work forward and backwards.....
    IMG_20170919_094159.jpgIMG_20170919_094216.jpgIMG_20170919_094207.jpgIMG_20170919_094226.jpg
    Jul 2004
    Houston, TX
    36 Cylinders
    RheingoldUSA is just reselling chinese clones with pirated software and calling them certified and mislabeling them as made in USA. All while making themselves look like they are some kind of official or something. Don't buy into that nonsense.
    This seller's cables have never given me any trouble, and I've had a few from them www.ebay.com/itm/291263858079
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Aug 2015
    Cologne, MN
    That's my cable. I think I'll try getting one from this guy and see what happens. I'd really hate to nuke my laptop and start over.
    Do you have the cable like this that you would be willing to pop open and snap a few pics?
    Nevermind....I just realized this one doesn't have a switch. It must be a software switch.
    Jul 2004
    Houston, TX
    36 Cylinders
    If you're going to be using it mainly on 2006 and older, then you can bridge in internally by soldering, or use a bridging adapter.
    -Abel
    Jun 2005
    Dirty MFin Jersey
    M3 Buildup
    the white cable you have will never do can cars from my experience... anything past early 07. I have about 15 of them in a junk bin for this reason
    Buy my native installed ISIS ISTA-D/ISTA-P bmw diagnostic laptop. More Info Here!
  1. Replies: 0
    Last Post: 08-21-2010, 10:43 PM
  2. Titanium Silver M3 at Braman pics..
    By Ben FR in forum 2001 - 2006 M3 (E46)
    Last Post: 04-05-2001, 09:51 AM
  3. Should I get silver or chrome contours?
    By BMWFAN in forum 1991 - 1999 (E36)
    Last Post: 04-03-2001, 10:54 PM
  4. FS: Philips Silver Vision Bulb
    By d0nut m3 in forum BMW Parts For Sale
    Last Post: 03-28-2001, 07:28 PM
  5. Is it me or is most E46's silver?
    By Stylin in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-21-2001, 11:33 PM
