Results 1 to 2 of 2
Thread: M42 Blower Fan issues
    Sep 2017
    Melbourne, Australia
    E30 318is, LS1 Ute
    Hi all, first post here. Just recently purchased a fairly clean e30 318is, slowly sorting through a few issues before I get it on the road.
    Air con/heating fans won't come on at all, when I click the air con button on I can hear the compressor. I'm also sure the relays are okay as the power mirrors are perfectly operational, fuse looks okay...replaced the blower resistor with a spare that came with the car, still doesn't work.
    Either I'll try a brand new resistor, or is it sounding likely the entire blower needs to be replaced ? I thought even if it were faulty, it would still show some form of life.
    Charlottesville, VA
    89 325i track, 91 318is
    Typically when the resistor is bad the fan will only run in high (4). If its not running at all you probably have another issue; wiring, fuse (#20), fan motor, etc. See page 6413-0 here; http://wedophones.com/Manuals/BMW/19...g%20Manual.pdf
  1. E36 blower fan issues - lessons learned
    By apatrizi in forum 1991 - 1999 (E36)
    Last Post: 07-18-2021, 12:38 PM
  2. AC blower fan issue
    By zmmnm3 in forum 1991 - 1999 (E36)
    Last Post: 04-04-2011, 07:36 PM
  3. blower fan issue help!
    By xxRookie325ixx in forum 1983 - 1991 (E30)
    Last Post: 01-06-2008, 01:18 AM
  4. blower fan issues
    By jsr198@yahoo.co in forum 1983 - 1991 (E30)
    Last Post: 01-22-2007, 05:34 PM
  5. Heater blower fan issue (not resistor)
    By erikras in forum 1983 - 1991 (E30)
    Last Post: 03-26-2006, 03:09 AM
