Results 1 to 19 of 19
Thread: Replacing Fan Clutch
    Apr 2012
    San Diego
    '99 528iTA
    Hey guys, just wanted some clarification for a fan clutch replacement.
    So I have your typical faulty fan clutch, it's always engaged and fan speed increases with RPM speed (sounds like an airplane). I've read on fan clutch replacement DIY's and the job is fairly straight forward, but I just wanted to know if there's anything else I should be replacing while doing the job like AC drive belt, etc. It's a 99' 528iA with 163k if that'll help with any info needed.
    Thanks in advance!
    - James
    Aug 2014
    Cheshire, CT
    1998 BMW 528i / 5
    To R&R the Fan Clutch, you only need to (half) remove the Fan Shroud and Expansion Tank. There's no need to open the cooling system (except for the small dia. return hose under the Shroud).
    If you're due for new belts, probably not a bad time to change them, while the Shroud is out. If you're due for a cooling system refresh (pump, t-stat, hoses, radiator, exp. tank), that's a bit more involved.
    But, at least change that Fan Clutch before the fan blades grenade off and ruin the engine bay.
    Ed CT
    1998 528i
    5-Speed
    Aspen Silver
    Aubergine Leather
    Oregon/Ukraine
    E39 M-Sport F30 M-Sport
    Not much you can replace while you are in there, the clutch fan removal only requires you to slightly raise the fan shroud.
    E39 WhatsApp Chat Gruppe
    San Jose, CA
    1997 BMW 540i 6 speed
    Left-hand thread. If you need a 32 mm wrench, get one at a bicycle repair shop.
    Consider replacing the fan, too. The blades are getting brittle with age and heat. Broken blades can also dimple the hood.
    Dec 2015
    Gardner MA
    2003 525iT, 2008 328xiT
    Quote Originally Posted by RuskiE39 View Post
    Except for a belt, tensioner and pully, maybe a new thermostat, upper radiator hose. Those all need at least a little movement of the fan shroud. And why move it two or more times when at 163k it very well need many of those items.
    2003 525iT Automatic, Topas Blue Exterior, Gray Leather Interior, Sports Suspension, Sports Seats, M 3 spoke Steering Wheel.
    2008 328xi E91 (wagon) Automatic, Barberatot Metallic Exterior, Terracotta Leather Interior.
    Oregon/Ukraine
    Quote Originally Posted by schatzy62 View Post
    It takes less than 10 minutes to get the shroud in position to remove the clutch fan. If you insist on doing all that other preventative you might as well do the OFHG, Vanos seals, a complete cooling system flush, and why stop there? Go ahead and lift the car up and replace the clutch while you've got the fan shroud off.
    Quote Originally Posted by edjack View Post
    A lot of auto parts stores sell the flat 32 mm wrench too. Napa, Auto Zone, O'reillys.
    Apr 2012
    San Diego
    '99 528iTA
    Quote Originally Posted by Ed CT View Post
    Exactly what I was wanting to hear! PO has had the cooling system overhauled (unsure at what miles it was all redone) but I might as well do them myself to know that it was replaced. Thanks again for the help!
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Can also try the $15 eBay bmw fan tool sets - the better of which include a better fan thicker wrench than a bicycle type, as well as the holder-wrench.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    I recommend these wholeheartedly. So much easier than trying to smack the 32mm I have from AutoZone with a dead blow.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
    Dec 2009
    Annapolis, MD, USA
    2012 JSW 2.5
    +1 replacing the fan with Genuine BMW fan
    Google search: e39 exploding fan
    [IMG][/IMG]
    Jan 2012
    San Diego, CA
    too many
    I replaced fan clutch for first time, last week, without removing any other parts. I had more than enough room, it was surprisingly easy (knock on wood). Hardest part was getting the 32mm loose. Using the fan clutch pry tool was waste of time. I had to hit the 32mm with mallet like a golf swing.
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by fullthrottle540 View Post
    The V8 cars have a lot more room than the I6 cars, for sure. I like the counter holding tool that is widely available on eBay.
    Nate J.
    Oregon/Ukraine
    Never had any issues using the little holder tool, and yeah, the 540 has a lot more room to get the blade out. You don't even need to move the shroud. 530 is annoying.
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Yeah, well, the inline six is longer.
    Oregon/Ukraine
    Quote Originally Posted by BimmrMeUpSnotty View Post
    That's what she said.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Here in Turkmenistan you it is difficult to find e39 with fan clutch. All of us removed it and replaced our OEM A/C fan to e60 A/C fan. Works great. No need fan clutch any more.
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by dovlet View Post
    Do you have a DIY you can share that shows how you did that?
    Nate J.
    Aug 2017
    Tampa Bay Area florida
    1998 528i
    I got my full fan clutch tools on Amazon for $16 dollars 2-day shipping to Florida with prime and got my meyle fan clutch for a decent price from FCPeuro. it wasn't that bad to get off though be careful when the nut breaks loose that you don't skin yourself like I did.
    1998 BMW 528i My First Build
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Quote Originally Posted by computiNATEor View Post
    Remove your OEM fan and connect e60 fan.
    Also, one friend of mine did the same with m54b30 engine
  1. info. needed on replacing Fan Clutch
    By JAM///535i in forum 1988 - 1996 (E34)
    Last Post: 08-11-2008, 08:59 AM
  2. Replacing fan clutch...when and why?
    By brianc in forum 1992 - 1999 M3 (E36)
    Last Post: 12-01-2007, 01:21 AM
  3. Replacing Fan Clutch
    By JustChill in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-25-2005, 04:31 PM
  4. replacing fan clutch?
    By bmw325is in forum 1987 - 1991 M3 (E30)
    Last Post: 06-22-2002, 04:54 PM
  5. Replacing Fan Clutch
    By Lone Star in forum 1991 - 1999 (E36)
    Last Post: 11-13-2001, 03:08 PM
