Collecting parts for my e30 turbo project.. my goal is to have all my parts collected by December and have the car up and running by spring. Anything I can find used or source from other members would be a huge help, so I thought I'd just put up a wanted list and keep it updated for the following months. Things that are already fabed up to fit an e30 frame running a 24v engine would be amazing and save me alot of time on the backend... things that aren't fabed up for the e30 frame but are proven to work well on an m50 engine are still highly desired! Message me if you anything you want to get rid of.
Things I Need List:
Charge Piping
Downpipe for top mount set up - would LOVE if someone had one I didn't have to weld one myself!
3" Exhaust
Oil Drain line
ARP Headstuds
44mm wastegate - ideally Vband
BOV - open to suggestions
Things I already picked up:
Garrett 57trim t3/t4
RSI (GoodNtight) turbo manifold
18x12x3 CXracing Intercooler
Megasquirt Pro PNP
LC-2 Wideband
Bosch 42lb EV1 Injectors
VDO Gauges and pod's set up
2.93 LSD
AN4 Oil Feed Line (still need drain lines)
Hallman Manual Boost Controller
I'll be running this set up in an m50tub25, planning on running about 9psi on stock internals and ARPs. Open to discussion and conversation about it but this is the plan thus far.
