Results 1 to 8 of 8
Thread: Headliner Question
    Jul 2017
    Marlton, NJ
    E36 325i M3 Conversion
    Headliner Question
    1992 325i - the headliner is start to pull off and is sagging in a lot of spots. If I understand correctly there is a fiberglass tray that is secured to the roof that holds the soft headliner material secured with a bunch of glue. Is there any reason other than aesthetics that I can't just take the whole thing out and leave it out? How bad is it going to be? Is there wiring or anything else between the fiberglass tray and the roof?
    Marietta, GA
    95 M3, 87 535is
    Theres some wires up front that control the dome lights and sunroof motor. Best bet is to just pull the fabric out and leave the fiberglass tray in place.
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by jayjaya29 View Post
    That leaves a fuzzy mess, IMO. Is this for a track car?
    I have seen those things painted, which isn't too bad for a track car.
    Jul 2017
    Marlton, NJ
    Yeah it's track only. I wouldn't mind painting it but to be honest I was trying to avoid dealing with the mess of old adhesive.
    Nov 2005
    MA
    bmw 330
    remove the headliner
    peel off the headliner fabric
    then spray it with fabric paint / spray
    You'll have all the benefits of a headliner but with none of the sagging !
    Jul 2017
    Marlton, NJ
    Can I spray that over the remaining glue residue or does that have to come off?
    Nov 2003
    VA
    1997 M3/4/5
    Quote Originally Posted by bigchallah View Post
    Pull the headliner out and it will all be clear to you. When the fabric is pulled off some residue will remain on the headliner, but it's easy to scrape off.
    I painted mine with truck bed liner. If I had a dark colored car I probably would've just left the headliner out. I saw a Daytona Violet with it removed and you didn't really notice, but with my bright red roof it was more obvious something was missing(the inside roof is the same color as your car). I love the way the headliner looks painted, but without the extra thickness from the fabric the edge that meets the rear window doesn't stay tucked in. Haven't had time to mess with it and figure out a solution yet.
    IMG_1485 by sammyzuko, on Flickr
    IMG_1484 by sammyzuko, on Flickr
    Nov 2012
    West Point, Virginia
    2002, 320is, 328is, M3
    Track car, get the whole mess out of there. While my car was slowly transforming to dedicated track car the headliner started to sag. If it don't make it go any faster it goes. Grab and rip but I would lose the whole thing. If you decide to leave the fglass in take a shop vac and a plastic bristle brush and you make short work of the adhesive and foam left behind.
    ME:"I want to make my car faster and lighter"
    THEM:" Get out and let someone else drive"
  1. Headliner Question
    By Blake2043 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-09-2005, 12:46 PM
  2. Headliner Question?????
    By shaft8869 in forum 1991 - 1999 (E36)
    Last Post: 12-21-2004, 11:52 PM
  3. 95-99 M3 Floor and Headliner question.
    By KozanBMW in forum 1992 - 1999 M3 (E36)
    Last Post: 11-02-2004, 06:30 PM
  4. Headliner Question
    By Preppy in forum 1991 - 1999 (E36)
    Last Post: 07-06-2004, 01:30 PM
  5. Headliner Question
    By mcdonaldb in forum 1992 - 1999 M3 (E36)
    Last Post: 01-08-2004, 06:50 PM
