eBMWParts
Results 1 to 10 of 10
Thread: For those who have installed Thrust (Torrington) Bearings
    Jun 2006
    Johnstown, NY
    99 M3, 13 Tundra TRD
    How do you get them to stay seated on the upper spring perch whenever you jack up your car?
    I'm installing a set all around, and can tell that they will fix my binding issue, however unless I hold them in place with my hand while lowering the car (not possible) I don't see how I can get them to properly seat into the upper perches.
    A couple pics might paint a clearer picture.
    Top of spring, bearings flopping to the side.
    Top of spring, me holding the bearings in place.
    Bottoms are fine
    Sent from my Pixel using Tapatalk
    Instagram
    Current: 99 M3
    Past: 84 325e, 84 528e
    Oct 2003
    Seattle
    99 M3
    I think they are intended to be used with 'helper' springs.
    Mar 2014
    Concord, CA
    1996 328i vert
    You aren't preloaded properly, the front completely unbound but installed should not allow room like that. You have a height adjuster and a preload adjuster. Adjust preload first then height.
    Jun 2006
    Johnstown, NY
    Quote Originally Posted by Pyropete82 View Post
    Thanks that makes sense. My car came with coilovers installed and haven't touched them until now. I've only ever used cup kits before.
    Instagram
    Current: 99 M3
    MINIz guy's Avatar
    MINIz guy is offline #buttstuff2k14 BMW CCA Member
    Bear, DE
    rolls coal
    Don't you only need 1 thrust bearing per spring?
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by MINIz guy View Post
    I would think only one bearing would be required.
    Middle of a corn field
    E39 hamster/ruberbandPWR
    I thought about installing these with my H&R coil-overs, since they have progressive spring, and they bind.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Jason5driver View Post
    Can't hurt. Linear or progressive does not matter.
    Sent from my iPad using Tapatalk
    Apr 2002
    Broomfield, Colorado
    Just wondering - what does spring bind feel like?
    2002 BMW M Roaster.
    1998 BMW 328is SCCA E Production road racer.
    Quote Originally Posted by CoMZ302 View Post
    The springs on my car will typically bind when entering or leaving the driveway at a turn / hard turn.
    You can feel and hear the coils of the springs crunch / bind against each other.
  1. Question for those who have installed rear headrests
    By pdx e34 in forum 1988 - 1996 (E34)
    Last Post: 04-21-2010, 08:55 AM
  2. Replies: 24
    Last Post: 08-25-2008, 09:29 PM
  3. For those who have installed suspension quick?
    By BIMMERBOYZ in forum 1983 - 1991 (E30)
    Last Post: 05-03-2006, 04:16 PM
  4. For Those Who Have Installed A-Pillar Gauges......
    By jmciver in forum 1991 - 1999 (E36)
    Last Post: 01-27-2002, 09:30 AM
  5. For those who have installed a UUC short shift kit...
    By Ben 93 325is in forum 1991 - 1999 (E36)
    Last Post: 01-07-2002, 09:40 AM
