RM European Auto Parts
Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: Engine Fault - Reduced Power
  1. #26
    dworthy's Avatar
    dworthy is online now Wagon meister :) BMW Tech Expert
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Well I would also be worried about the BUS. I do believe that all those sensors are using it to talk to the DDE, so it can be a problem there too.
    Also I would check the battery as it is a known thing for funky codes to pop up for a weak battery. So if the battery test good, clean the connections on the battery.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  2. #27
    Sep 2017
    Birmingham
    BMW F10 2010 520d
    Any idea where the BUS is located. I could check if it's receiving power etc.
    Also, do you think the DDE relay could have any part to play and where is it located.
    If the DDE was getting no power am I safe to assume it would not be able to talk to the Diagnosis Machine?
    Sent from my Nexus 6 using Tapatalk
  3. #28
    dworthy's Avatar
    Nov 2010
    The BUS is a communication line for the car, all the modules and sensors tend to use it to talk to each other IIRC.
    If the DDE relay was bad, the DDE wouldn't even power up, so you would be correct.
    How does the battery look?
    Darin
    Current:
    Past:
    M-Flight Member
  4. #29
    Sep 2017
    Birmingham
    BMW F10 2010 520d
    The battery is fine and so is the alternator.
    I've checked the relay housing and that is bone dry and all connections look clean same with ECU/DDE housing.
    I'm a bit stumped really, where would this BUS be located?
  5. #30
    dworthy's Avatar
    Nov 2010
    I am not sure on the F-10 as it is part of the wiring loom in that car.
    I am hoping that one of the dealership techs would jump on this thread, as they play with the newer cars, and I am at the end of my expertise here mate.
    Darin
    Current:
    Past:
    M-Flight Member
  6. #31
    Sep 2017
    Birmingham
    BMW F10 2010 520d
    Thanks for your help mate.
    I'm a bit stumped now
  1. X5 35D E70, Engine Malfunction, Reduced Power, fault code p02cb
    By 09X5diesel in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 09-13-2020, 09:40 AM
  2. BMW E60 525i, engine fault, reduce power.
    By frankkmh in forum 2004-2010 (E60,E61)
    Last Post: 05-13-2012, 05:30 PM
  3. New 535xi - Engine Malfunction Reduced Power
    By bishbmw in forum 2004-2010 (E60,E61)
    Last Post: 03-24-2012, 07:29 PM
  4. Engine Malfunction/Reducing Power
    By Flanker in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 11-24-2008, 08:49 PM
  5. 745i 2002 - Engine Malfunction - reduced power
    By hans745i in forum 1995 - 2001 (E38)
    Last Post: 12-04-2006, 07:37 PM
