Results 1 to 19 of 19
Thread: Dash / center console set
    Oct 2008
    Seattle
    E31 E38 E65
    I CANNOT do exchange on E31 sets. The original parts have a coating on them that doesnt work well with this surface process. sorry
    This set comes with these pieces ONLY. NO ASH TRAY DOOR AVAILABLE
    Also, If you notice this set has been customized with molded-in switch panels to create a "one-piece" look.
    Price is 340 shipped (USA)
    *~*Yamaguchi-gumi Syndicate Member #59,005 *~*
    [ Bippu Couture ] ( D_G ) [ FALKEN Tires]
    Nov 2013
    Whitney, TX
    97 850CI
    Nice work as always Drift.
    Desecrator of all things Sacred
    Oct 2008
    Seattle
    E31 E38 E65
    Quote Originally Posted by 72tpik5 View Post
    nice work as always drift.
    thank you!!
    Oct 2008
    Seattle
    E31 E38 E65
    bumps
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    Emerald,
    What are you using to make these if the panels have an incompatible coating? Are the new oem panels the bad ones or the originals?
    Oct 2008
    Seattle
    E31 E38 E65
    The new OEM panels require less treating to out-gass the ABS before the coatings are added and work the best.
    The old Original pieces have a textured coating that has to be removed and then it can be out-gassed. its just too much work to do the Original pieces when the newer versions work so well.
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by DriftGirl View Post
    I was thinking about sending my original pieces to you for a piano black finish, I would have to buy all new pieces to send you instead?
    Oct 2008
    Seattle
    E31 E38 E65
    absolutely get the newer pieces for that.
    May 2017
    California
    840Ci
    Hi DriftGril, I noticed that on the newer pieces the center piece has an open back and the inside does not come with a felt piece. Most of the E31s that I have seen (with or without wood trim) come with the felt piece and the close end. I can't figure out why the newer piece is missing that, is this BMW simply trying to cut corners?
    I always wonder how that open end would look like when installed. Do you have a pic of this in the car?
    Factory Center Piece
    Oct 2008
    Seattle
    E31 E38 E65
    yeah, I think BMW is cutting corners on these. new ones do not come with the felt linings
    No installed pics. my dash is custom and not easy to swap out
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    The phone delete insert has the lining but has not been available for years. The insert with the cutout (for the phone) does not have any lining.
    What "thumbs up" really means
    May 2017
    California
    840Ci
    Thanks for clarifying that
    France
    840 IA 1993
    Hello Emerald,
    I finally found your equivalent in France ...
    I would be less original because I chose the carbon aspect but I do more parts.
    I had a piece made just to see the appearance and in the end they will be matte varnish.
    Nov 2013
    Whitney, TX
    97 850CI
    Quote Originally Posted by NICO57 View Post
    Hello Emerald,
    Please post some pictures of the installed parts when finished. I like it.
    Oct 2008
    Seattle
    E31 E38 E65
    Hello Emerald,
    thats going to look REALLY nice when you are finished
    Oct 2008
    Seattle
    E31 E38 E65
    looks nice on the shelf collecting dust...would look better installed...buy it! :p
    Feb 2014
    Louisville, KY
    1993 BMW 850Ci
    Does anyone know how to reinstall the spring loaded door that covers the ash tray in the center console? I have all the parts but no idea how to reinstall them. Its the door in the post from NICO057 above the second piece from the left in his first picture. Thanks
    France
    840 IA 1993
    Quote Originally Posted by porphy View Post
    If that can help you : https://www.bimmerforums.com/forum/s...ior-Trim-Fixes
    Feb 2014
    Louisville, KY
    1993 BMW 850Ci
    Wow! Exactly what was needed. Thanks much! Merci beaucoup NICO57
  1. WTB: e36 black dash, center console trim
    By NightkidE36 in forum BMW Parts Wanted
    Last Post: 05-30-2007, 02:11 AM
  2. Replacement Dash & Center Console Moldings
    By PDX Touring in forum 1996 - 2003 (E39)
    Last Post: 02-22-2007, 10:09 PM
  3. WTB: e36 coupe, black-dash/center console 93?
    By ACS3 CLS in forum BMW Parts Wanted
    Last Post: 01-30-2007, 07:15 PM
  4. Fitting e36 Sedan Dash/Center Console into Ti?
    By Ahheck01 in forum 1991 - 1999 (E36)
    Last Post: 06-26-2006, 12:25 PM
  5. Replies: 0
    Last Post: 03-23-2006, 10:19 PM
