What are some of the must have tools you have come to need when working on your BMW beside the basic, wrenches and sockets? Looking to make a list for newcomers.
Sent from my SM-G955U using Tapatalk
Metric sockets, torque wrench, screw drivers, ratcheting wrenches, mig welder, extensions, torque sockets, reverse torque sockets, jack stands, low profile jack, dremel, angle grinder, safety glasses...that's off the top of my head of tools I regularly have used on mine.
CBlock
+1 for the mig welder and metal cutting tools. Also a hydraulic press, engine hoist, and engine stand. I use my dremel a ton also.
Perhaps more practical would be a master thread tap and die set. Ive run into a few stripped bolts now.
Breaker bar and torque wrench. A set of socket swivels, about 4 feet of extensions, and a gas torch (either propane or maap)
The only things I have specifically BMW is the Sealey trailing arm bush tool and an ADS interface + Diagnostics. A copy of TIS as seen on ebay is better than the online translated ones
You start off with the basics and make or acquire what you need over time
No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
if you have a clutch fan, then you will want a big ass wrench...like 32mm one... if you want to work on most things under the hood. homedepo sells them at a good price
Actually, you need the tools for the job you need to do next, not the tools we all suggest then find you have no money for the parts or tools you need when a job comes along
Lots of 10mm sockets.
+1 couldn't have said it better. Instead of quantity buy quality. Start with a high quality socket set and combo wrenches from 8-20mm. A decent set of regular and Phillips screwdriver. A quality jack and jack stands. Buy the rest as you need them. I love my hydraulic press and engine hoist but most e36 owners will never need one enough to spend that kind of money.
The German tool industry must have strong armed BMW to use every size nut and bolt head. In my experience, most manufacturers will heavily favor a few sizes but BMW gives them all there day in the sun l, internal and external torx included. I can't remember what part it was, but I ran into some 11mm recently. Who the hell uses an 11?
I agree with getting tools as needed and find out what loaner tools are available from you nearest auto parts stores. Get a complete set of metric wrenches and sockets including a sturdy pull handle (breaker bar). Many Utube videos are out there for common repairs and the often list every tool needed so you can have them before you start. Also be patient with stuck fasteners, use a combination of tapping, penetraling oil, heat and working a fastener back and forth to avoid wringing/snapping them off.
External Torx, buy the set
Another vote for just standard set of tools. Buy the fancier stuff when the project comes along. Yes it inflates the price of that particular repair but better than stocking your garage with tools you may never use. Then you wind up like me where I'm becoming the local tool supply for my friends.
Although looking through no one has mentioned tie rod separator, pickle fork, code scanner, dead blow hammer.
I was just changing subframe and diff bushings on my 08 E90 M3. I have 3 sets of female torx sockets. All stopped one size smaller than the subframe bolt. I used a 12 point 14mm socket to get by. As long as you don't impact it you can make do. But I will expand my already very large tool collection.
A set of punches and an engineer's hammer.
An extendable magnet pickup wand. It will save you hours of cursing.
Lime Rock Park... the most fun you can have in a mile and a half.
Must haves: Torx socket set.
Allen socket set.
Metric socket set up to 27mm. Ideally a 32mm socket to get the hydraulic tensioner.
A 22mm crows foot for the o2 sensors (Although if yours are completely fucked up you may strip the sensor so it may be worth investing in a dedicated o2 sensor socket).
Spark plug socket.
Ratchet with rotating/tilting head. <-- you'll never go back to a regular ratchet again.
Multimeter.
Jack.
Jackstands.
A baby ratchet like 3"-4" in length.
Nice to have: A mechanics creeper has been more helpful than I'd like to admit. Fast orange and simple green to get the shit off your hands. Maybe some motorcycle gloves that have the carbon fiber knuckle reinforcement for when you know you're going to be doing some real knuckle bashing.
I've used my BFH way too many times than I should admit.... That being said my guys have put together a little "BMW Essential Tool Kit" that's loaded with a hand full of "not so normal" tools that we've found to be handy over the years; 27mm 6-Point Socket, 30mm 12-Point Deep Socket, 36mm 12-Point Deep Socket, M18 Triple Square, and a BMW 14/17mm Service Wrench.
-James
A laptop with INPA, DIS, GT1 etc. for OBD2 cars
Nobody has a laptop with GT1, the correct model of laptop and software and interface is GT1, therefore you can't put GT1on a laptop.
Also no E36 is fully OBDII. OBDII is an engine standard anyway, so that means even on "ODBII cars" The instrument cluster and various other modules are ADS.
I do agree though, INPA, NCSEXPERT at a minimum and if you don't have a serial port a VAG COM / KKL / ODBII cable, unmodified, preferably with the FTDI232RL chipset and a 16 pin tot 20 pin adapter will do if you don't want to access the ADS modules.
