Results 1 to 25 of 65
Thread: 91' 318IS revival
    Nov 2005
    canada
    2001 740i
    91' 318IS revival
    I figured it was time to start a new thread on this. I picked up this E30 a couple of weeks ago which was being scrapped. I wasn't looking for one, just happened to be driving past a shop and saw it sitting in a parking lot. Car wouldn't start due to a bad fuel pump and owner decided not to fix it. At first sight it looked pretty beat but closer inspection revealed a pretty clean body and undercarriage. Interior was covered in trash though.
    When I inquired about the car the shop owner said it he would sell it to me for the price of scrap so naturally I had to have it. Worst case I part it out and scrap the rest.
    After getting it home and swapping a fuel pump for a Walbro it fired right up.
    The car does need quite a bit of work as it was neglected by the previous owner. I am planning on slowly bringing it back to life and doing small upgrades but mostly keeping it stock (famous last words).
    If there any Jalopnik readers on here you may have seen it already. http://jalopnik.com/what-the-hell-is...-us-1802714329
    I managed to fill up 2 large bags of trash with junk that was left inside the car. I think all the crap actually preserved the interior rather well because seats and dashboard looked pretty clean.
    After getting it running I decided to see if the paint could be saved. Couple hours later it was looking pretty good.
    I will probably be ripping the whole car apart by the looks of it, cleaning up, refurbishing and painting all the parts, replacing whatever is worn and reassembling.
    If anyone has any E30 parts laying around they are looking to unload I am looking for a few bits right off the bat (and that's before even taking the wheels off ).
    Finally got a chance to pop the wheels off and get a closer look at the suspension and brakes.
    Brakes look like they were recently done. Front strut is leaking so those will be getting replaced. Ball joints and tie rods are iffy so those will get swapped too.
    Front swaybar links are mint though. I guess I might as well get a set of Addcos for it.
    Anyone know where this connector goes? It was hanging off the rear end.
    So far here is my shopping list.
    Also, where is the best place to jack these cars in the rear and place jackstands?
    1991 318is
    2001 740i
    Jul 2006
    Portland, OR
    A couple of hooptys
    That wire is most likely to the brake pad wear sensor, located in the right-rear (also one in front-left) caliper's brake pads. Look up replacing those sensors (or disabling them if that's a route you want to choose). Best place to set the rear stands is on the rear subframe, not far from where you've got your jack. Lift the rear of the car from the diff so you can get both sides in the air at once, then set your stands. Clean car; nice project! Hopefully that subframe isn't a show of the rust in the rest of the car.
    1997 328i/4/5 - Cosmosschwarz Metallic on Dove Grey - Auto/Manual Swap - M3 Bilstein Sport/H&R Sports (95 M3 mounts) - Offset M3 LCAB - 20mm M3 rear sway bar - X-Brace - AA Tuning Strut Tower Bar - Rogue Engineering RSM - Dinan Cat-Back - 3.38 LSD - E46 330 front/328 rear brakes - SS Brake Lines - E36 fitment Style 42's (staggered) - M3 Front Bumper - M3 side moldings - M3 Rear Diffuser - DJ Auto Headlights (6k HIDS) - Frenched Fogs - OEM Clear Tails - E65 Rearview Mirror (Homelink controls + Autodim) - Alpine Type S Cabin Speakers (6x9 Retrofit) - 8" JVC woofer - Black Kidneys - Red Needles/Chrome Gauge Rings - OEM Alarm - Full Interior/Trunk LED Lighting - Mishimoto Full-Aluminum Radiator - More to Come!
    Oct 2016
    South Africa
    '09E90 LCi 320d, '98 E36
    Nice project, nicer V70
    Sent from my SM-G935F using Tapatalk
    Mar 2017
    San diego, California
    91 318is. 88 325 vert
    Original 18 is...hell of a find. Those cars are going up in value these days. How many miles on the motor?
    Nov 2005
    canada
    2001 740i
    There are a couple of rust spots on the body which will need attention but undercarriage is pretty solid. It's been oil sprayed as well as factory undercoating protected it rather well. Car has 329000 km or 205000 miles or so.
    1991 318is
    2001 740i
    323i E30's Avatar
    323i E30 is offline ⅂!ʈө !ƨ l!ʞө ɐ ʇөlөbµouө
    Jan 2013
    Europe
    M52 E30 touring & E91
    Very nice
    ^ true story
    D̶i̶b̶s̶ ̶o̶n̶ ̶t̶h̶e̶ ̶E̶2̶1̶
    Aug 2017
    Toledo, OH
    1991 325iC
    Heya, fellow Jalopnik here. Did you ever find out what that thing was in your trunk?
    Also if you decide to give up and throw in the towel, I'll take all your interior bits. ;-P
    Nov 2005
    canada
    2001 740i
    Quote Originally Posted by TheCathedral View Post
    Yes, I did actually. When we ripped that box apart there was a circuit board with a brand name. Turned out to be snake oil generator aka hydrogen injection system.
    Anyone know what BMW used to coat the wheel wells? Looks like some sort of rubbery coating, almost like seam sealer.
    1991 318is
    2001 740i
    Dec 2005
    Boston, MA
    '91 318is
    Quote Originally Posted by bymep View Post
    3M Body Schutz
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    no idea on the wheel wells but nice car. good deal for the price of scrap
    No e30s again.
    Wadsworth, Ohio
    BMW
    Nice find! Congrats on the project!
    And bingo on 3M Body Schutz, it's a cross between a spray on rubber and truck bed type coating.
    -James
    Nov 2005
    canada
    2001 740i
    Thanks for the info. Will have to pick some of that stuff up.
    While disassembling rear suspension I managed to strip the threads on one of the wheel hubs. I am seeing a couple of different part numbers available. What's the difference between the 2 other than price?
    https://www.fcpeuro.com/products/bmw...ar-33411131121
    https://www.turnermotorsport.com/p-2...325ees-325iis/
    1991 318is
    2001 740i
    Dec 2005
    No e30s, again :(
    no idea here, the page doesn't open. maybe one has the teeth for the antilock brake sensor to read and the other doesn't?
    No e30s again.
    Nov 2005
    canada
    2001 740i
    Sorry, I updated the post. Different part numbers but they look the same. I found a post on another forum saying that one is for earlier models and one for later to fit different size rotors?
    1991 318is
    2001 740i
    Dec 2005
    No e30s, again :(
    ohhhh, cool
    No e30s again.
    Nov 2005
    canada
    2001 740i
    This weekend I tore apart the rear suspension and dropped the subframe.
    Now, I have a question. Rear subframe aluminum mounts sheared off inside the body on both sides of the car. I found these images online. The large washer shown here is still attached to the body on my car. Is it suppose to come off or not?
    I am planning on replacing all the bushings with polyurethane or delrin. So far all the bushings that I found do not have this large metal washer. Do I have to reuse it or leave it off?
    1991 318is
    2001 740i
    Feb 2017
    State College, PA
    1991 BMW 325IX
    Glad you asked this question. I’m in the middle of doing exactly this myself and was hoping for a clear answer from someone. Right now, I’m assuming you *dont* use the washer/cap because I’ve watched several YouTube videos of people installing Powerflex subframe bushings and in none of them (including one by Bavarian Auto) do they mention using it.
    Regina, Sask, Canada
    82 320i 89 325i
    Are you referring to the mounting bolts that go up through the body ? Those bolts are removed by removing the rear seat bottom in the car and driving them up into the car from underneath. Normally accomplished by threading the lower mount nuts back on to the very bottom of the mount bolt, and whacking with a BFH, then fish them out of the mount holes inside the car. They will need replaced if you cut or otherwise damaged them.
    Yes you are gonna want that washer. It's essentially the upper subframe bushing mount pad. It often fuses to the bushing like it is shown in your pic as the inner bushing and washer are different metals. Mine were fused as well. A couple little pry bars made short work of it. A little heat might not hurt either, tho mine didn't need it.
    Dec 2005
    Boston, MA
    '91 318is
    they aren't expensive new from BMW
    item #12:
    http://www.realoem.com/bmw/enUS/show...diagId=33_0213
    82 320i 89 325i
    surprised no one jumped at this lol
    click on the thunbnail. gotta be the most famous e30 pic on the internet.
    Nov 2005
    canada
    2001 740i
    Thanks for that pic. I saw it online earlier.
    Another question. I discovered a rust hole in the fuel tank near a filler neck so I need to replace it. Looking on RockAuto I am not seeing a listing for a 318IS tank. I see them for 318I and 325 but nothing for IS. Do those use same tanks? I see a couple options available. 14.5 gallon with a single hole on top for fuel pump/sender or 16.6 gallon with 2 holes. Is it simply a matter of figuring out how many holes I have on top of mine for the fuel pump/sender and ordering that tank or does 318IS use a unique tank?
    1991 318is
    2001 740i
    Apr 2014
    DFW TX USA
    1983 320I, 1986 325E
    Start using realoem.com to look at parts diagrams and compare part numbers. You can probably find your answer there.
    Nov 2005
    canada
    2001 740i
    Quote Originally Posted by Thecatmilton View Post
    Bookmarked, thanks.
    1991 318is
    2001 740i
    Nov 2005
    canada
    2001 740i
    Time for an update.
    I hate rust and once I started poking I found some not so nice surprises. It's great that BMW covers the whole undercarriage in seam sealer. Not so great when moisture gets under it and rusts from inside out.
    This was the scene when I pulled rear of the car apart and scraped off the seam sealer from all visible rust areas. There are a couple of holes near rear spring mounts. One of the cross beams is iffy and a couple small holes in the floor where brackets for gas tank and fuel hoses were welded in.
    Fuel tank vapor hose tube was also rusted so that was first area that I repaired. Cut out rust, fabricated a patch panel then welded it. After that 2 coats of DOM16 which will be covered with seam sealer.
    Rear axle and control arms were ground down and wirebrushed to be as close to bare metal as possible then covered in 2 coats of DOM16 followed by a coat of Trem Clad.
    Leaky diff ripped apart and cleaned up. Diff housing and flanges will also be stripped of rust and DOM16 coating applied.
    Rear wheel calipers were soaked in a Metal Rescue solution bath for a couple of days to get them down to bare metal. I will be painting those later on.
    Next up I started patching up holes in the floor. The procedure is simple. Cut the rusty panel out, fab up a patch panel, butt weld it in place. 2 coats of DOM16, followed by seam sealer. Any metal that has surface rust and not rusted through gets ground down or wirebrushed to bare metal then covered in DOM16.
    More updates to come.
    1991 318is
    2001 740i
    Nov 2005
    canada
    2001 740i
    Progress is being made slowly but surely. One of the cross beams that sits between spring supports was quite rusty so I decided to replace it entirely. I wasn't able to find a part number for it so it will be fabricated.
    Rear seat belt buckle mounts had to be removed as well. I also had to weld a couple small patches in driver side frame rail around spring mount since they were soft.
    Meanwhile I've been accumulating new parts. The box in my basement is starting to grow rather quickly.
    1991 318is
    2001 740i
  1. WTB: 91 318is, 84-85 318i or 87-91 325is
    By Calvin_1976 in forum BMW Parts Wanted
    Last Post: 09-20-2002, 02:58 AM
  2. Internal coolant leak on my 91 318is
    By cohiba in forum 1983 - 1991 (E30)
    Last Post: 05-03-2002, 01:59 AM
  3. FS: pristine '91 318i
    By mdavis in forum BMW Parts For Sale
    Last Post: 06-11-2001, 02:42 AM
  4. 91' 318is coil?
    By Mr.Blonde in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-03-2001, 10:35 AM
  5. FS: '91 318i, white/beige, pristine cond.
    Last Post: 04-08-2001, 02:45 PM
