Gents, today i realized that my SC started to make new noise which i never heard before. Removed belt and noted that my pulley is out of size and it is shaking/vibrating. Also, a lot of black and metal dust behind of pulley between SC. Found machine shope and going to press inside new aluminium and make new insert. Hope i will be success. Some one faced with this kind of issue?
e39 540i 6speed Supercharged,
E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
Nope. Not really ever heard of w Vortechs AFAIK. Probably the bolt came loose and allowed some slop which then wore it out larger and larger. Amazing it didn't throw the belt.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
As you can see a lot of black dust is there.
Looks to me like the seal is leaking oil, and the oil is just picking up stray engine bay dirt.
Have you checked & changed your oil regularly?
Also, turn the compressor wheel then watch the shaft as it turns... its not bent or loose, is it?
Maybe supercharger needs a rebuild.
Probably this topic better in the forced induction forum too, more supercharger experience there than here.
2003 M3CicM6 TiAg
Former:
Yes, am changing oil timely. Shaft is strong with no shaking or vibrating.
dovlet
Join DateFeb 2016LocationAshgabatPosts372My CarsBMW e39 540i SuperchargeFeedback Score
Few days ago requsted machine shop to make something with my old pulley. Work done perfectly at least looks like. Here is some photos
Could you just buy a new pulley? Nice machine work.
Look at this Gents, just installed my new pulley and decided to check leakages from top site on SC. Looks like my shaft seal is damaged.
