Results 1 to 6 of 6
Thread: Coolant Leak middle back of the engine?
    Maine
    97 740il with 165K. Leak is smack in the middle of the back of the engine but I cannot see where the leak is from. The hoses to the auxiliary water pump mounted on the firewall middle drivers side seem okay and that pump and all its hoses were replaced like 2 years ago.
    I took off the engine cover, topped off the antifreeze and drove it 2 miles to capture the two videos attached. What I would love to know is what part/hose might have failed to generate this kind of a leak.
    Actually, I cannot see how to attach my two short videos - screen shot attached I hope.
    Thanks!
    Richard
    Maine
    Below is the link to the video - I hope this helps to isolate my problem. What I really need to know is, what part do I need to order? Thanks.
    lA, ca, lA
    BLK 01 sp, 20 Trail Boss
    Here a UTube video of how to replace the valley pan gasket it also shows all the hoses that can leak at the rear of the engine probably one of those hoses has gone bad judging from your video. https://www.youtube.com/watch?v=0E1vFrxQcqk
    Apr 2003
    Seal Beach, Ca.
    2003 540s, 2000 740s
    If it is one of those hoses that go from the rear of the engine to the firewall, of course just go ahead & replace all 4.
    Also, if you haven't replaced the CCV yet, now would be a good time to do so. It has a rubber membrane inside that gets old & cracks.
    And, if you do that, do yourself a favor & replace those Torx bolts with regular hex head bolts so it will be easier to unscrew them next time:
    http://www.bimmerboard.com/forums/posts/712363
    <== Steptronic Sealbeach740
    2000 740i sport: 74k Green/Tan chrome MPars, clear corners, quad brake lights, AIC hi-beams, Hoen fogs, 16x9 screen, MKIV, TFT LCD screen in back, license plate backup camera with "on demand" switch, iPod audio/video (CDC/iPod audio switching, iPod video on 16x9 screen), Basslink, gauge rings, ///M pedals, switched steptronic +/- shifting mode, E46 paddle shifter steering wheel, Dinan engine & tranny software upgrade, DDEs controlled via Euro fog light switch, painted calipers with "BMW" lettering, windows up/sunroof close via remote.
    2003 540i sport: 81k, Sterling grey/grey, MKIV Nav, PDC & CWP - Added license plate backup camera with "on demand" switch, paddle shift steering wheel, windows up/sunroof close via remote, Akebono's, painted calipers with "BMW" lettering, quad brake lights, iPod audio via AUX mode/video via 16x9 screen, BMW TV tuner, ///M pedals & gauge rings.
    Maine
    Thank you everyone! Ive ordered all the hoses and a CCV too. Do you recall the size hex I use to replace torx?
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    According to realoem.com they're M6x25.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
  1. Coolant leak from back of engine???
    By SmokeyDP in forum 1992 - 1999 M3 (E36)
    Last Post: 04-14-2019, 11:43 AM
  2. Coolant Leak from Back of Engine
    By CoolantProblems in forum 1991 - 1999 (E36)
    Last Post: 06-10-2014, 09:38 PM
  3. Coolant leak from back of the engine
    By croat in forum 1996 - 2003 (E39)
    Last Post: 06-10-2011, 03:26 PM
  4. Coolant leak in back of engine
    By e38tcp in forum 1995 - 2001 (E38)
    Last Post: 12-10-2010, 06:22 PM
  5. Coolant Leak from back of engine bay...
    By 328iJunkie in forum 1992 - 1999 M3 (E36)
    Last Post: 04-22-2007, 10:10 AM
