Results 1 to 9 of 9
Thread: Transmission -Can it Be Repaired?
    Sep 2008
    New York
    2004 Pontiac GTO
    (second thread I have started in 24 hours; since the 2 issues are totally distinct I thought they'd need separate threads. Hoping not to cause excess clutter going forward... appreciate the understanding Gentlemen).
    In the other thread I have spoken of my steering problems
    https://www.bimmerforums.com/forum/s...is-it-the-rack
    and here I would like to ask you all about the transmission issues please. This one will be shorter:
    I have a 1984 3.20i with the M20B30, stroked to 2.8 liters.
    The engine produces very lovely torque and pulls hard. I have no dyno figures, but can share one observation to give you an idea: In 1st gear on a flat surface, the car will move forward with no stutter or danger of stalling, by simply moving your foot off the clutch- no need to touch the gas. This is happening with idle revs of 800-850 or so by the way.
    Maybe because the engine produces such higher torque than factory specs or maybe due to abuse over the years, the transmission is pretty nasty though. There is no popping off gears, but I have a good amount of whine. I would not say the whine is crazy but it is there. In addition the car will go into gear with some difficulty -again nothing super crazy yet, but I would call the shift quality pretty bad. There is no grinding noise of any kind; rather pushing the lever into the right position is hard as it feels like it is going through some good amount of resistance while being pushed into place.
    Now this brings up the following interesting point of course: There is no grinding yet, but maybe that is because I am simply unable (and unwilling) to do a quick shift. Having to push like this, the car spends a good amount of time between gears. Maybe there would have been grinding if I was actually able to shift quickly.
    I am told by everyone not to try and get the current transmission fixed and that buying a new one is an easier and likely cheaper solution. OK, prices for used units are reasonable. However, nobody is able to tell, just by looking at a used transmission what the shift quality will be like.
    So 2 questions really;
    How does one buy a used transmission with any kind of confidence? Is there any way to tell before installing the damn thing?
    and is there any point at all in trying to get this transmission fixed?
    Thanks to all
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    1. You really can't. Used transmissions are always a crap shoot. Best you can do is get one with some kind of warranty but you're still unlikely to have labor covered. And if you find one with labor covered and it sounds like an unbelievable deal, research the company offering it.
    2. That depends on the rest of the car. But probably not.
    "Howdy, Folks!"
    Sep 2008
    New York
    2004 Pontiac GTO
    richardodn, thanks a lot Sir
    Now that is not good news, but hearing from you guys, who know these cars, is awesome
    can one buy a brand new transmission for a E30? I looked around and saw some units for crazy expensive prices for sale in the UK; does anything exist at somewhat reasonable prices over at Europe?
    Thanks again
    Sep 2014
    KS
    e24e30e36e39e90
    What about a rebuild job? I had the zf auto trans in my e39 rebuilt with good results.
    Dec 2012
    USA
    F10 6spd 3 E305speed
    Check this ad out I know the seller and the car. https://newjersey.craigslist.org/pts/6310169607.html
    Quote Originally Posted by omoplata View Post
    Thanks to all
    Sep 2008
    New York
    2004 Pontiac GTO
    Quote Originally Posted by sienayr View Post
    When I said repair, that is what I mean.
    By the way, as a general rule, is it easier to do a transmission rebuild on an auto or a manual?
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    I think manuals are easier because they are not run off line pressures or hydraulic pressure in the system. from my very limited experience with having a trans rebuilt, the autos never ran right because something was always larger than it was supposed to be somewhere hidden and it caused problems shifting (or not shifting)
    No e30s again.
    Dec 2004
    Huntsville, AL
    87 325is
    I used a rebuilt in my Spec E30 and was completely satisfied with the rebuild job. I used http://www.drive-gear.com/ for the rebuild.
    Jim Levie, Huntsville, AL
    Sep 2008
    New York
    2004 Pontiac GTO
    Quote Originally Posted by thejlevie View Post
    Is it OK to share how much this cost you?
    Thanks a lot
  1. Repairing Seat Belt Tensioner - Can it be re-soldered?
    By EthirtyS1X in forum 1991 - 1999 (E36)
    Last Post: 04-01-2017, 06:47 PM
  2. Cracked M5 E60 rim.Can it be repaired?
    By cavaselis in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 05-26-2011, 10:41 AM
  3. coupe door hinge, can it be repaired??
    By jmejia15 in forum 1991 - 1999 (E36)
    Last Post: 02-23-2011, 02:42 PM
  4. Help please - front boot is ripped - can it be repaired?
    By kurahee in forum 1999 - 2006 (E46)
    Last Post: 02-25-2010, 02:34 PM
  5. Replies: 1
    Last Post: 02-24-2010, 04:35 PM
