Results 1 to 8 of 8
Thread: Oil light
    Jan 2013
    Pittsburgh, Pa.
    2001 BMW 330ci
    Oil light
    2004 330CI....the oil light comes on and off with stops, starts, etc. stick shows full?...just purchased the car and it is leaking a little oil. any suggestions?
    Dec 2015
    Fresno, CA, USA
    2005 BMW 330Ci Coupe
    Well if the level is showing good on the dipstick I'd start with the oil level sensor. Make sure not to overfill the engine, that's the most important thing
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    How many miles on the car? How many miles on the oil and filter? If you can't answer that latter question, I recommend you change the oil and filter. The needs to have the "BMW LL01" logo on the bottle. The filter must be made by Mann. The engine takes 7 quarts of oil.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Which color is the oil lamp red or yellow?
    Red means low pressure, I would stop driving the car.
    Yellow means low oil in the pan. Yes the E-46 is pretty bad for having them go bad after 10 years, buy a Hella one.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    South Carolina
    2004 330 vert 2004 X5
    Is it one sensor for both pressure and level? Or separate ones?
    Dec 2013
    Chicagoland area
    EXOTICS
    Quote Originally Posted by MarcoZandrini View Post
    I totally agree with Marco, I would only like to add that you replace all O-rings#4,#5,in diagram:
    http://www.realoem.com/bmw/enUS/show...diagId=11_2201
    as the o-rings affect oil pressure.
    Jul 2017
    42 deg lat -70 deg long
    Yes, please.
    The oil level sensor should be replaced if the light comes on and off frequently when driving.
    Dec 2015
    Fresno, CA, USA
    Quote Originally Posted by Junglenut View Post
    Yes^ if the dipstick shows its full (which in my opinion is best way to check oil level since it isn't electronic) and it's blinking and stuff at stops or when taking of its most likely a defective oil level sensor. It's $50 so it's relatively cheap anyways. If you can get a high end scanner in there and test all modules and sensors.. but I'm assuming that just like me you don't have a $1000+ computer to test so I say start with the level sensor
  1. Oil Light flickering !!
    By jason11 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-21-2002, 05:41 PM
  2. oil light??
    By M3corey in forum 1992 - 1999 M3 (E36)
    Last Post: 08-21-2002, 08:43 AM
  3. Oil light flickered, idle dropped at stoplight...
    By PSU///M3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-03-2002, 06:59 AM
  4. Low on oil, idiot oil light did not go off! and question on gauges
    By M3Jokster in forum 1992 - 1999 M3 (E36)
    Last Post: 01-15-2002, 03:30 PM
  5. Oil light comes on after a long run up the canyon!!
    By JasonJ75 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-15-2001, 02:19 AM
