Results 1 to 25 of 25
Thread: Wheel Restoration Thread - BBS RC041s
    Jun 2016
    North Carolina
    03 525it/5, 1967 GTO
    Decided to track my progress on bringing these wheels back to stock condition. Lots of similar split wheel threads but these are kind of rare Stateside so why not.
    Current condition after someone painted the faces gloss black. Plan is to strip the paint, media blast, polish the barrels and powder coat sparkle silver:
    Untitled by Twistytee, on Flickr
    Remove bolts with 10mm 12-point socket:
    Punch them out with a H12 allen socket:
    Would prefer new bolts but this is a budget job and they're a little bit grimy so into the hot bath they go:
    Crock pot from the local thrift store and some aluminum safe degreaser:
    First batch out of the hot bath:
    Wire brush to remove excess paint:
    Trip through the vibratory tumbler to remove remaining corrosion:
    Medium of choice for the tumbler cleaning:
    Advance look before experiencing an overnight polish job:
    Aluminum faces with some road grime needing a polish job:
    Light curb rash requiring a sand and refinish job:
    Stay tuned for additional installments.
    Sep 2015
    Kansas
    93 318is
    I like the crock pot idea... Never seen that before
    Sent from my Z983 using Tapatalk
    Jun 2016
    North Carolina
    It won't remove rust, but it's a good way to dissolve grease and loosen old paint before polishing nuts and bolts. Soaking for 24-48 hours in a 50/50 mix of CLR also works and acts on the rust, but because it's acidic it can pit the finish if you leave them in the solution too long.
    Jun 2016
    North Carolina
    Removed the valve stems with a utility knife and punch:
    Hardware came out of the tumbler reasonably well-polished. May still zinc plate them for corrosion resistance:
    Went with Jasco paint remover. Burns if you get it on your skin so I used relatively thick nitrile gloves:
    You can see the clear coat peeling once the paint remover starts its job:
    Aluminum rim starting to look better after the second pass with the Jasco and microfiber towel:
    Barrels after clear coat removal and tar and road grime cleaning. Haven't started to hand polish yet.
    The prior paint application was a double coat of enamel - wasn't a powder coat job so hopefully removal will be easier.
    Close-up after the Jasco has been allowed to set-up for a bit. These will be going into the blast cabinet when I finish stripping in order to prep for new paint:
    The Netherlands
    DE-spec E36 328i/M3 cab
    Nice.
    Love these wheels. Had a set back in 2007.
    IG:
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Subd. I LOVE diy projects
    mslevin's Avatar
    mslevin is offline Have you checked RealOEM? BMW CCA Member
    Dec 2015
    Sunnyvale, CA
    E36, E38, E46
    Looking good! Love that crockpot idea, I'll have to look out for one at Goodwill.
    Jun 2016
    North Carolina
    Thanks for the positive comments. Slow going this weekend. Got the hardware cleaned up on the other two wheels and continued working on paint stripping including the waffle caps. Hoping to media blast them this weekend and just ordered my powder and clear from Eastwood. Traveling a lot for work so paint will get delayed a bit but I'll keep at it.
    Sep 2012
    Moscow, Russia
    1992 318iS, 1997 328iS
    Very good job! We're waiting for happy end!
    Jun 2016
    North Carolina
    Started working the faces in the blast cabinet today. Had trouble with the media clumping - lots of humidity in the air. I must have drained a full pint or more out of the water traps in my air system.
    Glad the waffle caps on the RC041s are metal - it will enable me to paint match them with the powder coat. Still waiting on paint to arrive to finish these off.
    Next fall project - need to paint match my hardtop and redo the headliner. Found a local body shop who will do it for a reasonable price.
    Jun 2014
    Santa Clara, CA
    F30 '14 328i Msport
    Thanks for sharing the updates
    Sep 2002
    Vancouver
    98 M3
    Love these wheels. Looking forward to seeing the progress.
    - 98 m3, techno/anthrazit cloth, 124k and officially worthless - 89 m3, alpine/black 143k and officially old - 2000 323it, tiag/grey, 169k and officially boring
    Nov 2002
    Pot Hole NYC
    Turbo E36 M/Jeep Wrangle
    Nice
    Jun 2016
    North Carolina
    Finally finished stripping the black paint from all four wheel faces. Probably should have paid to have them professionally dipped or had the finish baked-off. I have way more hours into this phase of the restoration than I thought it would require.
    I can finally see the original BBS stamps and part numbers. They were previously buried in layers of paint.
    My wheel paint arrived. Next step is powder coating the faces once I can find a free weekend.
    Jul 2006
    Portland, OR
    A couple of hooptys
    Great write-up; excellent looking wheels. I spent a lot of time refinishing my RS wheels for my E36 (in sig) and it was time very, very well spent. When I got to refinishing my E30 wheels (Italian made OZ Ruote Fittipaldis), I took the same approach and went a step even farther making them exactly how I wanted them. It does take a long time, but it really makes you appreciate what you've done, and when you do it right, it lasts much longer. Do it once, do it right! Good work.
    1997 328i/4/5 - Cosmosschwarz Metallic on Dove Grey - Auto/Manual Swap - M3 Bilstein Sport/H&R Sports (95 M3 mounts) - Offset M3 LCAB - 20mm M3 rear sway bar - X-Brace - AA Tuning Strut Tower Bar - Rogue Engineering RSM - Dinan Cat-Back - 3.38 LSD - E46 330 front/328 rear brakes - SS Brake Lines - E36 fitment Style 42's (staggered) - M3 Front Bumper - M3 side moldings - M3 Rear Diffuser - DJ Auto Headlights (6k HIDS) - Frenched Fogs - OEM Clear Tails - E65 Rearview Mirror (Homelink controls + Autodim) - Alpine Type S Cabin Speakers (6x9 Retrofit) - 8" JVC woofer - Black Kidneys - Red Needles/Chrome Gauge Rings - OEM Alarm - Full Interior/Trunk LED Lighting - Mishimoto Full-Aluminum Radiator - More to Come!
    Jul 2004
    Oconomowoc,WI
    1997 328iC
    Quote Originally Posted by Twistytee View Post
    Just curious. What was the quote. I am picking up a hardtop next week, and will also need paint. I may just plastidip it for the time being.
    1997 328ic
    1999 528i
    Jun 2016
    North Carolina
    Quote Originally Posted by StealthBimmer View Post
    I'd consider the plasti dip route and see how you like it. They quoted $500, but turned out they were assuming leaving the window in-place and masking the trim. You can probably add another $200-300 to that in labor if they remove the window and all the trim for full paint. You're definitely better off finding a matching top or going with a black one. And they almost all need a new headliner by now given the foam backing fails with age.
    Jun 2016
    North Carolina
    Back at it this weekend. Sanding down the rim that had some curb rash using 80, 220, 400, 800, 1,500, and 2,000 grit. Followed-up with some Meguiars rubbing compound and metal polish.
    Pretty happy with the final finish considering these wheels are 23 years old.
    Did the wheel caps next. Used a similar process with the various grades of sand paper and finished with the Meguiars polish.
    Left one has been polished and the one on the right is still pitted with road grime.
    Had a spare set of graphite BBS center caps from my RX wheels that happened to fit so will probably go with these over replacement BMW caps.
    Set-up my powder coat station and got to work painting the centers.
    Waffle caps getting powder coat too.
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Exciting!
    Jun 2016
    North Carolina
    Test fit for color comparison. I haven't shot with clear yet and also still need to re-plate the bolts. I was originally intending to go with a closer match to the OE silver finish but ended-up using a more contrasting rally silver. Gives a bit of a two-tone look with the polished rims, but I'm not 100% sold. My car is Mauritius Blue Metallic. Opinions?
    The Netherlands
    Contrast is nice, but not this color. Then I’d go oem silver.
    Here’s an old pic (2007) when I had these wheels, to give you an idea.
    IG:
    Jun 2016
    North Carolina
    Got around to applying a new coat of Sparkle Silver over the base coat of rally silver. I think this will look nice when I get them bolted back together.
    Mock-up
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Love the combo!
    Jun 2016
    North Carolina
    Thanks! Found a local plater who does zinc. Plan to clear chromate the spline bolts and put them back together soon. Hope to finish the job and mount 'em later in November.
    Jun 2016
    North Carolina
    Getting very close.
    Switched to the Mother's aluminum polish to complete final stage finish since it was available locally, lot's of black dust and tarnish coming off the rag.
    Used some Meguiars mirror glaze and good 'ole Klasse - German sealant to protect my German wheels...
    Got my original BBS bolts back from the plater. Went with zinc clear chromate finish for corrosion protection. Pretty happy with the end result.
    Need to bolt these back together and order tires. I know the early Ms ran square 235/40/17s on the 17x7.5" wheels. Anyone know if I'll have clearance issues with non-M Koni struts up front on a 325i? I'm on OE sport springs if that matters. I may get spacers later to get them flush, but would prefer to bolt them sans spacers for now. Since this tire size gives me relatively limited options, should I consider 225/45/17 instead?
  1. WTS: Perfect set of 4 BBS RC041/042 MTech Wheels
    By ixm3 in forum Wheels and Tires
    Last Post: 11-24-2010, 12:45 AM
  2. another wheel restoration thread
    By jrcook320 in forum 1975 - 1983 (E21)
    Last Post: 01-15-2010, 04:31 PM
  3. Replies: 7
    Last Post: 04-15-2009, 02:15 AM
  4. E36 rear wheel bearing (new), full set OEM lug bolts, BBS RC041 center caps
    By DiScoTeknix in forum Suspensions, Springs & Shocks
    Last Post: 09-08-2008, 02:44 PM
  5. FS: Forged e36 M3 BBS RC041 17x7.5 wheels
    By sfgearhead in forum Wheels and Tires
    Last Post: 07-12-2008, 01:53 AM
