How do you tell if your e36 is obd1 or obd2?
built late 95, no d connector under dash, vin decoder doesnt say anything, can't seem to find anything on real oem.
Chances are, if theres no OBD under the dash and you have a diagnostic port under the hood in front of your power distribution box, then you are OBD 1. I have a 318 with a production date of 8/95 and it is indeed OBD 1.
OBD II standard defines the diagnostic socket shape. Therefore if you don't have the socket it's not compliant.
No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
m42 motor, build date 9/95, stomp test doesn't work.
How do I get codes?
ALL CARS MANUFACTURED FOR SALE IN THE 1996 MODEL YEAR, OR LATER, ARE OBD II.
The '96 model year began production in September of 1995. Look at the VIN, the 10th digit indicates the model year. Look at the door jamb, there is a sticker on it that gives the VIN, and it also indicates the Production Date.
Never mind. I gave information that is only true for the USA.
Just because you are having trouble getting the stomp test to work does not mean the stomp test does not work. I think the M42 is an OBD I motor, so the stomp test should do the trick.
Turn the key to Position II (RUN) before Engine Start and fully depress and release the gas pedal 5 times within 5 seconds. It is hard to do.
^ Euro spec cars, which they probably had in NZ had the wire from the X20 IIRC it's name, to the cluster left out. On the 94 325 the stomp tests were still in the ECU and you just added the wire and bulb OR use a test lamp on the connector (switched earth) or use an ADS interface for the Motronic with tweaked INPA files
The open standards didn't yet exist in Europe so basically the features were incorporated for US market but it suited the manufacturer to protect their dealers advantage i.e. dealer diagnostics required at a guess
http://www.bimmerforums.co.uk/forum/...37/index5.html
IIRC green flashing light on my test lamp means switched earth
1998 BMW M3 3.2 Cabrio • Alpinweiß III on Schwarz • German spec • 1 of 12
IG: https://www.instagram.com/iflok/
And what's more, the European specific market also got the 320i. (I'm sure the regulars know exactly where I'm going with this!)
The 320i should have the Siemens MS40.0 or the MS40.1, depending on whether or not you have VANOS. I know some early E36 320i did get the Bosch Motronic DME, but many got the Siemens. This DME is wired completely differently, and has zero support for a Check Engine Light (if you don't believe me, search up the wiring diagrams yourself).
All diagnostic capabilities are carried out through the connector in the engine bay.
Tim96 - you need to tell us what sort of E36 you have to help us give the right advice. There isn't much point in my waffling about the 320i and Siemens DME when you might have a 325i with the regular Bosch Motronic!
Wouldn't even European vehicles have the secondary air system on the exhaust for obdll?
I know this is an ancient thread, so please don’t ride me for that. Lol. I have a 1995, 318 I convertible. I have an OBD2 scanner and I bought an OBD one extension connector for it. Plugs in just fine where it supposed to Under the hood driver side. I cannot get it to connect or link with my vehicle. I don’t think I’m doing anything wrong. Position two ignition etc. Car just won’t link and the OBD SAYS: not linked yet again lol. HELP!
