BMW E30 E36M roll-center bump steer angle kit
BMW roll-center/bump steer/angle kit for solid E30/E36M control arms with 41mm outer hole diameter (or E46 aluminum control arm with 50mm outer hole diameter)
The new revised kits now available!
-30mm roll center correction
-30mm bump steer correction
-30% quicker steering ratio (around 1 less turn on the steering wheel)
-lots of more steering angle
-adjustable Ackermann angle, orginal for street/race, zero for drifting
-fits with orginal tie rods (trimming of the thread required for strut clearance)
-minimum wheel size 15" (370mm inner diameter) on E30 strut, 16" on E36 struts (or E46 LCA)
-steering angle reducers recommended on street/race use
-comes with instructions, mounting hardware and of course MagnusRacingTeam decals
-Control arms and tie rods NOT INCLUDED
Why do you need one?
When lowering your car (BMW E30, E36, E46 etc.) the front end geometry goes wrong. The main purpose of the kit is to correct these issues. The adapter changes the wheel bearing to control arm joint distance by 30mm correcting the roll-center and camber curve, same thing applies to tie rod end which is also moved closer to control arm joint changing the lever ratio giving you quick steering and allowing way more steering angle. The new special feature is Ackermann adjuster, you can insert it either way: remain the orginal angle for street/race or decrease the angle to zero giving you desired handling for drifting and even more angle!
Does it fit my car?
The kit fits E30, E36 and E36 M3 spindles/struts, just mention the struts you have and we will include the right mounting hardware. These won't fit E30 M3 or E30 iX.
Control arm bearing adapter only fits E30 and E36 M3 solid control arms with 41mm diameter outer end hole, not E36 base model control arms! Some aftermarket E36 base model control arms without the rubber bushing part might have the suitable bore too, but confirm before buying! If you want to use it in your E36 base model, one solution is to swap E30 control arms, they have the same geometry.
E46 aluminum LCA 50mm bearing adapter also available!
Is it easy to install?
The kit comes with instructions, if you know how to change a control arm or an outer joint, installing this is not any harder. You'll need a press for removing the old outer joint and pushing the new adapter in. No other special tools needed. If you need any further info please contact us!
How about the lifetime and service of the kit?
The kits and bearings have been proved on street and track by many of our customers. We have had the very same bearings as is with no maintenance for 15,000miles through the year in daily use without signs of excessive wear. However when the bearing life comes to end, they're easily replaceable! Bearings are available around the world from automotive or industry dealers. Of course any of the spare parts can be bought separately directly from us.
We want to keep our customers 100% happy thus we're only using the best materials and manufacturing process available. All parts are CNC machined: aluminum parts are AW-6082 with hard anodized finish (silver and black), steel pins are made of CrMo tool steel and adjusters are stainless steel. ARP? fasteners are used in critical areas.
List Date: 9/15/2017
For more info, click here to view the original listing: BMW E30 E36M roll-center bump steer angle kit
On Sale For: $359.00
