Results 1 to 15 of 15
Thread: 1993 325is Accelerator pedal stopped working
    May 2015
    Fresno, Ca
    1993 BMW 325is
    I have 1993 BMW 325is AT 170k. Driving home my accelerator pedal abruptly stopped working. No power, no gas, just depressed all the way to the floorboard woth no resistance. Luckily I was down the street from home and coasted in. Engine fires up, but gas pedal is all the way to the floor. I noticed Transmission light on on dash. Any help greatly appreciated!
    Apr 2017
    NJ
    1995 318ic
    Have you popped the hood and checked the accelerator cable running to the throttle body? Could have snapped the line, mine was stretched out only at 50k miles, but i've heard of them snapping before..as for the trans light i have no idea hopefully someone with a little more experience can help you out..good luck!
    May 2015
    Fresno, Ca
    1993 BMW 325is
    Hi, thanks for your reply. Yes, I checked the throttle and it revs the engine when I move it with my hand. Just nothing with the gas pedal.
    Apr 2017
    NJ
    1995 318ic
    Quote Originally Posted by skyebaby22 View Post
    Just to confirm, when you press the pedal, does it pull the throttle at all? You should be able to see if you open the hood peek through the space between it and the windshield or just have someone press it while you look at it yourself.
    Anyhow, it sounds to me like the accelerator cable snapped on you, or at the very least, stretched too much. I believe a new cable is only about $20. Its not that tough a job the only pain in the ass is gonna be routing it through the firewall.
    May 2015
    Fresno, Ca
    1993 BMW 325is
    I don't believe it does. I don't hear the engine do anything. I'll have to have somebody help me out and check for sure.
    May 2009
    Greenville, SC USA
    e39 M5 e39 540i6 e83 e53
    Above the gas pedal is a tiny rubber grommet that holds the accelerator pedal cable in. Over time they dry rot and the cable comes out. I've had this happen to 2 of the e36s I've owned. It's a PITA to replace, scary when it happens, and a shitty design but pretty sure that's your problem. Part number 35411152331 (#14 below)
    Sponsored links
    May 2015
    Fresno, Ca
    1993 BMW 325is
    Ok, I'll order that piece and the cable too just in case. Thanks for your input!
    Any instructions regarding the repair?
    Apr 2017
    NJ
    1995 318ic
    I would find the end of the cable where it has a bit if a hook shape and give it a pull to see if it is still attached before you order the parts. If it is then just throw a ziptie around the hook end and snake it thru the hole in the lever portion, thats what i did. Or you could replace the grommet, I cant imagine it being more than $5.
    May 2009
    Greenville, SC USA
    I paid about $6 shipped from ebay for mine. The repair is straight forward, just kindof a PITA due to location. Remove the knee bolster so you can see what you're doing.
    May 2015
    Fresno, Ca
    1993 BMW 325is
    Ok, sounds good. I'm expecting the part to be delivered on Tuesday. Thanks for the help.
    May 2015
    Fresno, Ca
    1993 BMW 325is
    Done! Thanks again for the help. You guys are awesome!
    Apr 2014
    UK
    1995 BMW 328
    Ideally you should look and see if this is the cause before ordering
    No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
    Jun 2005
    DALLAS
    325IS
    while you are down there, look at part #10( there are 2, one on each side, and also #2) they are similar to #14 but larger and they also break and deteriorate. if the do, the pedal will have play in it.
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    Open the hood.
    Engine off.
    Have a helper operate the throttle pedal while you observe the movement in the engine bay.
    If there is movement, fix where the movement stops.
    If there is no movement, fix the gas pedal.
    In the parts diagram above, Items 7 & 8 are variations of the same thing. You have one or the other, not both.
    May 2015
    Fresno, Ca
    1993 BMW 325is
    Quote Originally Posted by TITE3NBIGD View Post
    Thank you!
    Quote Originally Posted by JDStrickland View Post
    Open the hood.
    Engine off.
    Thank you! I replaced the grommet as suggested by Auto Parts Guy. There was a piece of a broken black grommet on the ground near the pedal. Worked like a charm.
  1. 94 325I trans just stopped working, no noise, nothing
    By jeciii in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-18-2017, 08:26 AM
  2. help! gas pedal stopped working.
    By los809 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-28-2016, 08:01 PM
  3. 2002 325i air blower stopped working
    By lalokio in forum 1999 - 2006 (E46)
    Last Post: 07-07-2013, 09:00 PM
  4. 92 bmw 325i m50 gauges stopped working
    By slav in forum 1991 - 1999 (E36)
    Last Post: 11-28-2011, 03:33 AM
  5. 1993 325is 5-speed in Wisconsin, needs work, $3k obo
    By SlickDizzy in forum BMW Cars For Sale / Wanted
    Last Post: 05-08-2006, 08:02 PM
