Results 1 to 6 of 6
Thread: What is the likelihood of the rear subframe bushings failing on a 325xi.
    Jul 2016
    Edmonton, AB CAnada
    1992 325is turbo
    Sent from my SM-G930W8 using Tapatalk
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    Because the torque is distributed through the transfer case approx 68% to the rear wheels and 32% to the front wheels, that means that it less likely for a 325xi to have issues with rear subframe bushings wearing out or subframe cracking issues. However, it all depends on environment and abuse. Best way to check is to get under it and inspect them with your eyes. The natural torsional forces will wear the drivers rear and passenger front bushings first.
    I have a 2004 325xi and replaced the rear subframe bushings at 140k, but they didn't need it. Did them because I already had the rear out replacing other things.
    Sep 2008
    Sandy, Oregon
    2002 330Ci, 1995 325is
    Do they salt the roads where you live? That would be the main culprit.
    Jul 2017
    42 deg lat -70 deg long
    Yes, please.
    likelihood of 325xi rear subframe bushings failing is heads or tails.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    BMW fixes the cause of the problem in MY2002 by increasing the thickness of the metal wheee the rear sub-frame mounts to the body. Don’t worry about it.
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    The likelihood is AGE related. Rubber can flex very well over usage but TIME also factors in. Rubber and rubber- synthetic plastics, deteriorate over time ..they don't last forever.
  1. What is this part of the chair called?
    By Jamos in forum 1995 - 2001 (E38)
    Last Post: 07-23-2013, 04:39 PM
  2. what is this part of the intake?
    By jmitro in forum 1992 - 1999 M3 (E36)
    Last Post: 12-04-2005, 08:52 PM
  3. What is your usage of the OBC?
    By GiddyupM3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-23-2004, 10:37 PM
  4. Frayed what is your reveiw of the AA RTB's
    By elliott9601 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-12-2002, 07:35 PM
