Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 8 of 8
Thread: ► APEX | Camber Plates for Street, Track and Race
    California BAY AREA
    e30 M3, 335d
    Camber Plates Available at APEX
    We have helped the enthusiast community for years find the right camber plates to complement their street or track wheel setup. Selecting the right camber plate can be frustrating with all of components and options to choose from so we took our years of experience and developed an easier way… simply select your chassis, your intended use and order with confidence.
    We chose Ground Control Camber Plates for many reasons. Ground Control has been building world-class street, autocross/track, and full road race suspension setups since the 1980s. From camber plates and adjusters, to complete bolt-on coilover kits, Ground Control has designed and built setups for hundreds of different chassis and applications. All Ground Control camber plates feature a proprietary bearing, made to their specs by Aurora in the USA, which allows for articulation of the shock shaft. These spherical bearings are very under-stressed, as the Ground Control design does NOT support the weight of the car on the spherical bearing. Instead, the weight of the car is supported by a completely separate articulating needle bearing, which is also manufactured for Ground Control in the USA.
    Visit our website to order
    Street, Touring & Race Camber Plates
    1. Street Plate
    If you enjoy your car predominantly on the street, these plates are for you. These are ideal for those who carve back country roads, push their luck on the occasional freeway on-ramp, or attend a few autocross or high performance driving events (HPDEs) per year. They use a urethane bushing instead of a solid metal bearing to support the strut, so they transmit far less noise, vibration, and harshness (NVH) vs. the Race plates. If you want negative camber without the metal-on-metal suspension feel, these are right for you.
    2. Touring Plate
    Available for newer BMW models, Touring plates provide a broad range of camber and caster adjustment to ensure your alignment settings are ideal for any track or race environment. These plates are a new Ground Control design, specifically for newer F-chassis BMW models, and they can fit OEM springs, as well as 2.25,” 2.5,” or 60mm coilover spring diameters. Like all components engineered to maximize performance, some additional noise, vibration, and harshness (NVH) may be experienced, although it will be extremely minimal with this new design.
    3. Race Plate
    Race plates provide a broad-enough range of camber and caster adjustment to ensure your alignment settings are ideal for any track or race environment. Ultimately, Race plates are best suited for drivers who prioritize performance and a direct steering response over all else. Like all components engineered to maximize performance, the genetic makeup of race camber plates may induce noise audible in the cabin. This is similar to the decision many people face when choosing between OEM flexible rubber bushings or solid polyurethane. Most customers prefer the adjustability and solid design of the race plates, and are happy with the trade-off.
    The Positives of Negative Camber
    If you enjoy driving your car in a direction other than straight, you'll feel the benefits of negative camber immediately on your first drive after installation. Dialing-in negative camber increases your tire's contact patch during cornering, which means more grip, less outer tire wear, and ultimately, faster lap times. And these benefits aren't limited to track use, you'll notice them every time you drive your favorite on-ramp or mountain road. We can go on for days about the benefits of negative camber, and we do! Check out our technical article.
    Find Your Camber Plates
    Camber Plates Available For:
    Questions about camber plates, suspension and wheel fitment?
    Click here to get a personalized fitment recommendation from one of our experts.
    Ordering and Contact Information
    • Hours: Monday - Friday, 9AM to 6PM PST
    • Shipping: All orders are shipped directly from us via UPS. Local pickup also available at our Livermore, CA Warehouse. (Map It)
    California BAY AREA
    e30 M3, 335d
    Most camber plates are in stock and will ship the same day. Let us know if you have any questions about what fits your car.
    California BAY AREA
    e30 M3, 335d
    Ground Control quality and APEX service - truly a winning combination.
    California BAY AREA
    e30 M3, 335d
    We carry Street and Race plates with coilover or OEM spring perches. Let us know if you have any questions about what works best for your setup.
    Jan 2018
    orange county
    1970 2800CS
    www.apexraceparts.com = 502 gateway error
    can't get to the site
    California BAY AREA
    e30 M3, 335d
    Quote Originally Posted by CSGuy View Post
    There was some temporary downtime recently, it's since been fixed.
    Let us know if you have any specific questions!
    California BAY AREA
    e30 M3, 335d
    Coilovers not required. Ground Control Street Camber Plates can be configured to work with lowering springs like H&R, Eibach, etc, or even your OEM springs. Send us a message or give us a call with any question.
    California BAY AREA
    e30 M3, 335d
    Adjustable camber plates do more than just aid in wide wheel and tire fitment. They provide increased grip and reduced tire wear by spreading the load evenly during cornering.
    Check out our article, The Positives of Negative Camber.
  1. feasibility of two-setting camber plates for street and track
    By aaronhoy in forum 1992 - 1999 M3 (E36)
    Last Post: 02-13-2013, 05:57 PM
  2. KMAC camber plates for E36 (M3 and all)
    By Z3M in forum BMW Parts For Sale (Panjo) sponsored by Bavarian Auto Recycling
    Last Post: 02-12-2007, 10:18 AM
  3. How do you correct alignment with camber plates for steet/track
    By Jim M3 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 11-04-2005, 12:56 PM
  4. Best Camber Plates for Street/Track setup?
    By 94is in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 04-07-2005, 06:29 PM
  5. What are the best camber plates for Street/Autox/Track?
    By Stee in forum 1992 - 1999 M3 (E36)
    Last Post: 02-02-2003, 09:16 PM
