Results 1 to 3 of 3
Thread: Need help wiring replacement tail light on F23
    Sep 2017
    Rochester, NY
    2016 228 Convertible
    Replacing tail light that was broken by hit and run (bummer). New Taillight requires Repair Cable which has two brown wires. No wiring instructions were provided. I see a brown wire that goes into the 8 wire connector. Has anyone completed this repair? Thanks!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Brown is ground in a BMW.
    Sep 2017
    Rochester, NY
    Thank you. Finally got in touch with a dealer that knew something about this. The tail lights for this model was regularly burning out because of grounding problems so they added this extra pair of ground wires. I attached one to each screw that holds the tail light i place and everything is working OK.
  1. Replies: 2
    Last Post: 06-13-2017, 11:32 PM
  2. Need help with replacing tail light bulb
    By Erkinak in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 09-17-2007, 12:54 PM
  3. Need HELP! to replace Fog lights on 2000 X5,
    By shokher in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 07-23-2006, 10:11 PM
  4. Need help with my tail lights.....
    By m34fun in forum 1992 - 1999 M3 (E36)
    Last Post: 03-09-2003, 02:55 PM
