I fitted my e92 with the FLA high-beam assistant camera, and everything works perfectly. I noticed that the old VIN still appears in INPA or Gini. I have tried to change the VIN using the FGNR Schrieben command in NCS Expert without success. I also tried the TOOLSET32 commands. It says job okay, but the VIN doesn't actually change. I even used WinKFP to flash the module and change the VIN, but the old VIN is still there.
Can this be changed, or should I just leave it alone?
Did your WinKFP settings have the write UIF checkboxes checked?
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
WinKFP is the way to go. FLA file is quite small and the whole flash would take 1-2minutes and can be easily done with D-CAN cable as long as you have the Daten loaded. NCS won't change the VIN, neither Tools32.
Changing the UIF settings to default did the trick. That little sucker took 8 minutes to flash via ICOM A2.
