Results 1 to 5 of 5
Thread: popup headlamp malfunction
    brooklyn, NY
    850i/audi s8/lambo lp560
    hello 8'ers. when i put my pop up headlamps on, only the left side popped up but the right side does not. the lights coming out of the headlamps work fine and come on with the headlight switch up but the right side won't pop back down after i flip the switch off. has anyone had this problem before or can tell me what they think could be going on. thanks
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The most likely candidate is K39 - the headlight relay:
    http://www.meeknet.co.uk/e31/Timms_B...lay_Finder.htm
    It contains a PCB with a small amount of electronics and the relays - the joints on the PCB fatigue after a while and can usually be successfully re-flowed. The fatigued joints are not immediately obvious, so get out the flux and soldering iron and all will be fine afterwards!
    My BMW Repair YouTube Channel
    Jul 2014
    Westfield, IN
    '91 e31 M70
    Yes. It is typically the green headlight relays. The solder just get tiny micro cracks. Get someone to give you a hand and lightly press down on the pop up relay in the engine compartment relay box while they are operating the headlights. Sometimes you can get the solder joints to make contact to verify that's the issue.
    If you are a DIYer, there is a write up in this forum somewhere on how to reflow the solder to correct the issue. Not complicated, but a bit of a delicate operation. Why would someone go to those lengths to fix a cheap little relay instead of replacing it you say? Well, unfortunately, these headlight relays for our cars (3 in total) are around $175 EACH!
    '07 e65|N62 - Alpina B7 - Black Sapphire|Black|Loaded|GONE
    '02 e46|M54 - Orient Blue|Beige|'Vert|GONE
    '00 e39|M52 - Anthrazit Metallic|Grey|GONE
    '01 e38|M73 - Anthrazit Metallic|Schwarz|Shadow-Line|GONE
    '91 e31|M70 - Schwarz|Schwarz|M70|FOR SALE
    '13 328i Auto - Black Sapphire|Coral Red|Sport Line|GONE
    '05 545i SMG - Jet Black|Black|Bamboo Anthracite|GONE
    '07 335i Auto - Montego Blue|Grey|GONE
    '05 545i SMG - (Euro Delivery 7/22/05)|Black Sapphire|Auburn|GONE
    '97 528i Auto - GONE
    Dec 2009
    Gardendale, AL USA
    1995 840 Ci, 1959 Sprite
    Yep, at least $180 or so to buy new. It took all of 10 minutes to reflow the solder. I could not see any cracks or corrosion but reflowing immediately cured this problem. Try it!
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    We have had great results re-flowing the solder as well on 3 cars here in AZ
    Regards,
    Brian
    Cave Creek, AZ
  1. Headlamp Malfunction - Please Help
    By gunn353 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 02-10-2011, 08:33 AM
  2. Active Headlamp Malfunction
    By NitrousNick in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-07-2011, 09:58 PM
  3. Replies: 24
    Last Post: 09-10-2010, 12:08 PM
  4. HEADLAMP MALFUNCTION?!?! help please. 2003 745Li
    By POSTDUP in forum 2002 - 2008 (E65, E66)
    Last Post: 04-04-2010, 12:39 PM
  5. Cornering Light Malfunction????Adaptive Headlamps
    By cencalrealtor in forum 2002 - 2008 (E65, E66)
    Last Post: 02-17-2010, 02:05 PM
