Results 1 to 6 of 6
Thread: Door lock/handle bracket replacement / repair
    Cenral PA
    87 325is,91 318is,R53MCS
    I'm having a hard time finding a way to replace my broken handle bracket (see photo) RealOEM shows it as part of an assembly , which is also NLA.
    I have also found that it is a shared part number with the e34 5 series, which may help me if I need to source from salvage.
    I remember seeing a thread from someone who repaired the bracket, but can't find that thread now. Ideally I would rather replace vs. risk repairing it only to have it break again later.
    Any help is appreciated!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Cenral PA
    Thanks Shogun!
    so if I get a salvage yard assembly, I could get a rebuild kit to get the lock set to match my oem key correct? Or is it easy to reassemble the new bracket with the original lock?
    Jan 2005
    Japan
    the easiest + fastest is to fix the broken bracket http://www.bimmerboard.com/forums/posts/561068
    If you want to change more, it is more work,
    You can use the original lock. Go to my website, other diy links, there is the site of Jon Evans, he has pics and a write up for the doorlock
    Mar 2016
    Lincoln, NE
    91 735iL
    I replaced my original door handle with another since the PO hacked everything up. It's very easy to swap the key lock into a new handle. Also finding the correct handle can be a pain. Make sure you source one just like the one you have and not another version. The e34 has a few different ones depending on the year.
    Jan 2005
    Japan
    and one more door lock bracket fix http://bmwe32.masscom.net/johan/door...k_bracket.html
    51211928767 Lock with code, left , From: 06/01/1986 To: 11/21/2014 ENDED
    Superseded by:
    51218116379 11/01/1989 — 06/08/1993, nonexchangeable retrospectively, 51218116383 1/01/1989 — 01/11/2017, Exchangeable retrospectively
    51218148673 07/01/1991 — 03/28/1996, nonexchangeable retrospectively, 51218148677 07/01/1991 — 03/04/1996, Exchangeable retrospectively
    51218160903 02/01/1994 — 01/11/1996, Exchangeable retrospectively , 51218199749 05/01/1995 — 02/03/2016, Exchangeable retrospectively
    Supersedes: 51211928761 (06/01/1986 — 07/26/1993), Part 51211928767 was found on the following vehicles: 5' E34 03/1987 — 12/1996, 7' E32 10/1985 — 04/1994
  1. Front exterior door handle bracket pivot repair
    By e24pilot in forum 1995 - 2001 (E38)
    Last Post: 05-08-2017, 03:15 PM
  2. Get the darned door lock/handles out - handle/latch linkage
    By Auzeras in forum 1988 - 1994 (E32)
    Last Post: 12-20-2013, 08:46 PM
  3. E39 FS E39 Right Side Door Parts (Door Lock, Handle, Regulaor, Window Actuator etc.)
    By 540ig5 in forum Exterior Lighting & Body Parts
    Last Post: 07-10-2012, 09:28 AM
  4. Replies: 5
    Last Post: 06-10-2010, 12:59 AM
  5. Door Locks/handles
    By danniysh in forum 1991 - 1999 (E36)
    Last Post: 09-23-2007, 04:52 PM
