Results 1 to 8 of 8
Thread: 2011 E90 328xi squealing
    Michigan
    325i
    My 2011 328xi has about 125,000 miles. I bought the car with 35,000 and have not changed the serpentine belt or tensioners. On Friday morning it was a bit cold out and when I arrived at work after about a 30 minute drive the engine was squealing loudly at idle.
    The noise has been intermittent since then and takes a bit of driving (warm engine) to start. Then it subsides a bit as the RPMs increase to became nearly inaudible at highway speeds and 3,000 RPMs. But at idle it is extremely loud and high pitched.
    I was thinking to replace the serpentine belt and idler arm pulley. But admittedly have no idea where the noise is origniating. Yesterday my best mechanic friend (good with engines but not BMWs) thought the sound may be coming from a bit lower in the engine compartment guessing an air pump?
    Any guesses if I should just R&R the belt and idler pulley? or ?
    Dec 2012
    North Carolina
    2009 335i M-Sport Coupe
    Definitely do the belt, idler, and tensioner. If that belt shreds for any reason, it can get stuffed through the front crankshaft seal where it can wreak havoc inside the engine.
    Quote Originally Posted by elvirb87 View Post
    this is how i look at it from my perspective.
    If you buy an M5 and don't drive it hard its like paying a hooker for a hug.
    Michigan
    325i
    Thanks, I replaced the belt and idler arm pulley Wednesday night the sound disappeared. Gone Thursday all day as well. However sure enough this morning it returned along with the slow/rough idle. I didn't replace the tensioner. Should I look into that air pump? or tensioner next? should I replace just the tensioner pulley or the entire assembly?
    Atlanta, GA
    2017 Ram 2500d
    The tensioner and pulley is one assembly.
    There is no such thing as an air pump on your BMW. Are you talking about the a/c compressor? For what it's worth, I've had a few N52 power steering pumps make noise. But it's a fairly distinctive sound. Kinda like a whining more than a squealing.
    BMW Level 1 Master Technician
    2017 Ram 2500d
    2017 Jeep Grand Cherokee
    2014 Moomba Mobius LSV
    Michigan
    325i
    Thanks White, the squealing was from the very bottom of the belt area, could have been the A/C compressor, but turning the A/C on/off seemed to make no difference? also turning the wheel didn't change the sound at all either?
    Also while at Autozone I thought they would sell the pulley only for about $60 and I paid $115 for the pulley and tensioner?
    I think the part numbers were
    PULLEY - BMW (11-28-7-535-860)
    BELT TENSIONER - BMW (11-28-8-624-196)
    Michigan
    325i
    Here is a link to a 15 second video recording of the sound if that might help anyone, thanks!
    https://www.flickr.com/gp/127124632@N03/91125F
    Dec 2012
    North Carolina
    Quote Originally Posted by dabagboy View Post
    I haven't heard a sound quite like that before, that's very loud and high pitched. Does the sound change based on rpm?
    Michigan
    325i
    Quote Originally Posted by RocketSurgeon View Post
    Thanks for listenin -- yes it silences at about 2500 RPMs, very loud at idle and decreases as I accelerate or simply rev the engine.
  1. 2011 E92 M3 engine into a 2006 E90 328xi
    By rabidburn in forum Engine Conversions
    Last Post: 12-02-2016, 09:41 AM
  2. E90 328xi - 2011 Bumper kit on a 2008??? (CAN THAT WORK??)
    By chipopeloto87 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 10-21-2015, 10:29 AM
  3. 328xi 2011 e90 Brembo Brake Kits Wanted
    By eskimko in forum Wheels and Tires
    Last Post: 10-12-2013, 07:15 PM
  4. e90 328xi AT vs superchaged VW Passat AT
    By marcello7x in forum Kill Stories
    Last Post: 10-08-2007, 02:17 AM
  5. Drove the Loaner E90 328Xi..
    By Chinny4290 in forum General BMW sponsored by Intercity Lines
    Last Post: 08-31-2007, 01:35 AM
