Results 1 to 5 of 5
Thread: E46 - Intake Manifold swap from 325 to 328 ?
    Sep 2016
    Netherlands
    BMW E46 328CI 99'
    Hello everyone !
    I couldn't find nothink specific on forum about rly popular topic which is swapping intake manifold from E46 325 to E46 328. I've heard after swap + remap it makes arround 20HP gain.
    I've found there was 2x 2.5L engine models in E46 - M54B25 and M52TUB25. At this point I've got 2 questions:
    1) Intake manifold which makes a HP gain is a version from M54B25, right ?
    2) If I'm going to buy a 2.5 manifold is there anythink else I need to swap to my 328 ? Does anythink else fits plug&play ?
    My Best Regards !
    Jul 2004
    Houston, TX
    36 Cylinders
    A better intake manifold for actual gains on the 2.8 is from the M54B30. Skip the M54b25 manifold as it will not help you as much.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Sep 2016
    Netherlands
    BMW E46 328CI 99'
    Are You sure ? I 've read alot about problems with configuration of 330i manifold with no results - it seems making completely no difference... I've read allso alot about swaping it from 2.5L with impressive gain of HP.
    Sep 2016
    Netherlands
    BMW E46 328CI 99'
    Indeed the 328 Power 04 was right. I was just REreading everythinkabout thoose throttles, manifolds and other stuff around it.
    I got my all answears and topis is for CLOSE.
    If some1 is still interesting about swapping M54B30 Manifold to M52TUB28 engine that's all i could learn:
    1) You need only 4 things: Manifold, DISA controller from M54B30, adapter for throttle, CAI.
    2) Changing injectors, etc is pointless. Stock 328 injectors are fair enought till 235~240 HP
    3) After swap everythink works perfect, without any errors, problems etc. Allmost everyone admit manifold makes much better sound and performance gets higher.
    4) If You realy want to swap manifold it would be realy good if you make a remap - it double HP gain.
    Jul 2004
    Houston, TX
    36 Cylinders
    I consider it absolutely necessary to remap (tune) the ecu after this manifold swap. I did it to my M52tub25 Z3, and learned how to tune it myself. Managed to regain most of the lost torque by proper DISA control and much intake camshaft VANOS experimentation.
    Without tune, you're not taking advantage of the manifold properties at all. Especially since MS42 closes the DISA at 6000rpm.
    -Abel
  1. Intake Manifold Swap: The answers to your questions of late.
    By Hornung418 in forum 1999 - 2006 (E46)
    Last Post: 06-28-2019, 07:50 AM
  2. 540i intake manifold swap from a 1995 740i?
    By 540i6e39 in forum 1996 - 2003 (E39)
    Last Post: 03-18-2011, 07:27 PM
  3. intake manifold swap from m52b25 to m50b25
    By brothersister in forum Forced Induction
    Last Post: 03-16-2010, 10:32 AM
  4. 330 intake manifold swap in 325
    By Sephiroth13 in forum 1999 - 2006 (E46)
    Last Post: 04-23-2009, 05:12 PM
  5. Why does BMW constantly change their model numbers? from 325 to 328 etc?
    By abelhands in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-27-2009, 02:23 PM
