Results 1 to 6 of 6
Thread: Steering Box Pentosin leak
    CT
    E31, E24
    The seal on the shaft of the steering box on my '96 840Ci has apparently failed, as I am rapidly losing fluid. This box has 146K miles on it.
    I have located another box with 100K on it that is not leaking. Before having this box installed, should I have it rebuilt with new seals? I have no idea what the typical useful life of a box is before seals need replacing, along with any worn parts.
    Given the amount of labor involved in changing out the box, I am leery of simply having the second lower mileage box installed without having it reconditioned first. However, a rebuild plus shipping will likely run around $600, so it is expensive enough that I don't want to just casually have it done if it is really likely to be unnecessary.
    I am eager to hear from those of you who have steering box experience!
    Thanks in advance,
    --Steve
    SteveCT
    E31, E24,
    F30 daily driver
    Apr 2012
    Austin, tx
    1997 BMW 840, 1995 850
    I tried, with no luck, to have my box off a '95 850 rebuilt. Seems that every rebuild kit the mechanic tried had one wrong seal and he could not source that seal separately. Ended buying a rebuilt one off Ebay for much less than your $600. No problems yet, and it comes with a one year warranty.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I re-sealed quite a number of M70 steering boxes, on most no leaks, one I had probs and solved it with new seals + liquid seal on the housing surfaces.
    Is there a kit for the 840 steering box?
    But at least the problem for the power steering pump kit 840 is solved, there are apparently no seal kits on the market but master6 has now one, "I now offer a DIY repair kit for the LUK LF-68 used in the e31 840"
    https://www.bimmerforums.com/forum/s...Repair-Service
    Last edited by shogun; 09-11-2017 at 06:30 PM. Reason: added "power steering pump"
    SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
    http://twrite.org/shogunnew/topmenu.html
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    Steve, let me know when you figure out what you're really doing.
    I'm not going to cripple a perfectly steerable parts car unless I have to.
    '91 Dinan 860 Stage III (soon to be Dinan TT 6L)
    '91 850i 6sp (mint)
    '91 850i 6sp (getting there)
    '90 Dinan 750iL TT stage III
    '94 850 CSi (being restored to factory perfect)
    '94 840ci (4 short - obvious parts car), '91 850i parts car
    '73 3.0 csi, '08 535i, '95 318i
    CT
    E31, E24
    Harold, I think you misinterpreted my query--I was simply seeking info about whether or not it was wise to put in a used box (i.e., yours) without having the seals replaced.
    That being said, I don't think you should cripple your perfectly steerable parts car-- there are other boxes available out there. I do however, appreciate your willingness to do so on my behalf.
    SteveCT
    E31, E24,
    F30 daily driver
    CT
    E31, E24
    Shogun,
    Jay's kit is for the PSP, not for the steering box.
    S
    SteveCT
    E31, E24,
    F30 daily driver
  1. Replies: 7
    Last Post: 12-31-2011, 02:21 AM
  2. 318is Steering Box Leak -- Advice??
    By TomPotlatch in forum 1983 - 1991 (E30)
    Last Post: 12-06-2011, 07:10 AM
  3. Steering Box Leak
    By Jenya in forum 8 Series (E31)
    Last Post: 11-04-2011, 11:34 AM
  4. Power Steering Box Leak
    By Pabloel in forum 1976 - 1989 (E24)
    Last Post: 10-20-2011, 02:12 PM
  5. Power Steering Leak - from the steering box?
    By Avec in forum 1988 - 1994 (E32)
    Last Post: 08-01-2011, 01:47 PM
