As the title states, I am parting my 2003 M3 Carbon Black/Dove interior with 6 spd and 131,xxx out after deciding it was not worth it to repair the rear axle carrier panel. Seeing as the car was not in a collision of any kind, all parts are available and in good working condition. I will post pictures of the whole car, please text me (610-392-1fivefive0)or PM for pictures of individual parts.
PARTS THAT ARE EITHER SOLD OR NOT AVAILABLE (I will update this section as parts sell):
S54 WITH HARNESS AND ALL ACCESORIES/DME
FRONT BUMPER SUPPORT
FUEL PRESSURE REGULATOR
GAUGE CLUSTER
ZHP KNOB
TAIL LIGHTS
NAV HEAD UNIT
PASSENGER FENDER
DRIVER FENDER
DRIVER HEADLIGHT
CORNER LIGHTS
DRIVER DOOR
DRIVER DOOR MIRROR
HOOD
ALL OTHER PARTS ARE AVAILABLE (PARTS ARE OE UNLESS OTHERWISE STATED):
6 SPEED MANUAL TRANSMISSION - $550 **TRANS HAD OCCASIONAL GRIND INTO THIRD GEAR, COULD BE THE SYNCHRO GOING OR COULD BE AS SIMPLE AS A FLUID CHANGE**
HEADERS WITH EGT SENSOR AND 02 SENSORS - $250
EXHAUST SECTION 1 - $125
MUFFLER SECTION WITH TIPS IN FAIR CONDITION - $200
SKID PLATE - $90
FRONT SWAY BAR (COMES WITH ENDLINKS) - $80
FRONT STRUT TOWER BAR (WITH TOWER MOUNTS, ALL HARDWARE/CAPS) - $150
AFTERMARKET EURO FRONT BUMPER COVER - $150
OEM REAR BUMPER COVER - $300
OEM SIDE SKIRTS - $150
///M3 DOOR SILLS - $60
STEERING WHEEL W/ AIRBAG - $250
OVAL REAR VIEW MIRROR - $250
STEERING LINKAGE W/ U-JOINT - $50
PASSENGER DOOR W/ WINDOW GLASS - $175
PASSENGER DOOR MIRROR - $125
PASSENGER XENON HEADLIGHT WITH LED HALOS - $75
DOVE GREY DOOR PANELS (ALL 4, NO HANDLES) - $200
SEATS (NON HEATED DRIVER, PASSENGER, REAT SEAT WITH SIDE PANELS) - $200
DASHBOARD (WITH VENTS, NO TRIM) - $175
CARPET - $50
HEADLINER (SUNROOF CAR) - $100
OR YOU CAN TAKE THE ENTIRE INTERIOR FOR $550
ENTIRE SUNROOF CASSETTE UNIT (WITH GLASS) - $200
WINDSHIELD GLASS - $200
REAR WINDSHIELD GLASS - $125
REAR WINDOW GLASS - $75 PER SIDE
TRUNK - $200
STEERING RACK (WITH LINES AND RESERVOIR) - $200
CONTROL ARMS (WITH LOLLIPOPS) - $125 PER SIDE
STOCK STRUTS AND SPRINGS (ALL FOUR CORNERS) - $350
BRAKE CALIPERS, CARRIERS , ROTORS, PADS (ALL 4 CORNERS WITH SPINDLES AND HUBS) - $400
STEERING COLUMN - $400
COMPLETE REAR SUBFRAME (TRAILING ARMS, DIFF CARRIER, ALL BUSHINGS, MINUS DIFFERENTIAL) - $400
FRONT SUBFRAME - $100
DRIVESHAFT - $150
DIFFERENTIAL - $500
AXLES - $150 PER SIDE OR BOTH FOR $250
RADIATOR - $50
OIL COOLER (WITH LINES) - $120
MORE PARTS ARE AVAILABLE, PLEASE CONTACT FOR PRICES/PICTURES/AVAILABILITY
bump accepting any reasonable offer
is it an 03 or 03.5?
-M3J0N
willing to ship the transmission?
Manual or power seats?
