Dear all,
I want to know about FMU whether it helps me to achieve good results on tuning of my SC car. Does it helps to retard or advance my ignition timing?
Which unit you prefer to tune engine FMU or some Piggy Back or stand alone?
e39 540i 6speed Supercharged,
E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
Just get a tune.
1989 535i - sold
1999 M3 Tiag/Dove - sold
Benefit- Cheap
Disadvantages- Inaccurate fueling, no timing control.
Get a real tune, weather it be by stock DME or a standalone. FMU's and piggybacks are obsolete at this point.
