So I finally decided its time to do a turbo build on my 1997 328i w/ 135k miles. I have been wanting to do this for awhile now but I finally bought the parts and am hungry for boost. I have done a lot of reading on this and other forums, but I have by no means seen it all like all 156 pages of rajicase's build thread, so any and all help is appreciated. This is going to be my autocross car and my fun daily so hopefully I can make this a pretty reliable yet fun build.
Bottom mount build
Parts I have:
Garrett GT3076R turbo with a .63 A/R housing
Tial 38mm wastegate
HKS SSQV Blow off valve
Manual boost controller
Oil pressure, aem wideband, and boost guage
FX stage 2 clutch kit (using new pilot and release bearings from pelican parts)
Walbro 255 fuel pump
27X7X2.5 intercooler
s52 camshafts
ebay 2.5" intercooler piping
M50 manifold
Rallyroad motor mount arm
Parts I need:
SPA manifold**
Oil lines, coolant lines, vacuum hose
Exhaust Piping and muffler
Tune (Most likely RK tunes package with 60# injectors and maf)
Crankcase Evacuation kit
**In regards to the SPA manifold I am having some issues, I ordered a T3 manifold from their website about 2 weeks ago and noticed that nothing was happening with it so I tried to contact them and apparently their email isn't accepting emails and when I call, it just goes straight to a pre-recorded message so I am kinda bummed about that. I have to try and cancel the order and buy it from Rallyroad or if anybody has one that they are willing to sell to me.
My plan for this initial build is to run fairly low boost at around 8-9 psi with the stock compression or whatever I can do that is fairly safe. I plan to stay on pump gas, but I think all I have access to around where I live is 91 or at the most probably 92 somewhere, ill have to do some more looking. I have two m52 engines so while one is in the car I am going to try and rebuild the other so I can put it in later and increase the boost. I will be trying to do most if not all the welding myself. Trying to keep a/c if I can, but its not a huge deal breaker.
I know the turbo is very small and the exhaust housing is even smaller, but I was going for a very responsive turbo so I figured I would see what this got me and then when I finish building the other engine I can upgrade the turbo. So I think I should be able to get around 330rwhp, correct me if I'm wrong.
The main questions I have right now are:
- What size restrictor fitting do i need to put on my turbo for the oil feed line? .035"?
- How do I go about modifying the m3 front bumper to accommodate the intercooler?
I'm probably forgetting stuff, but let me know what you think, advice, if you have any extra parts I could use, I'm open to it all. I can add pictures if wanted or if I get some good ones, looking forward to joining the boosted club. Thanks in advance.
I would check out other tuners :wink
.035 is common for bb turbos
The bumper reinforcement black aluminum needs to be clearanced on the horizontal parts..
You'll need 3" piping on the cold side of the intercooler for virtually every tuner.
1989 535i - sold
1999 M3 Tiag/Dove - sold
Okay great, ill look for that fitting. why not rk tunes if you don't mind my asking and would TRM be a good alternative?
I was doing some fitting yesterday for the intercooler and I saw what you mean about the black aluminum reinforcement and I think I can get that 3" piping on the cold side but where do I route the hot side piping of I'm trying to go around the ac compressor. It looked like it might be able to make it through between the sway bar and the steering rack off to the side of the ac. thank you for the help.
You either run the piping under the subframe/control arm or use some bends to get it around the a/c comp if going over subframe. A good amount of people going over subframe weld a 90 onto the turbo to make the transition towards the front of the car.
you may need to move your horns on the cold side. There are many ways people configure the piping.
This is the order in which I would recommend tuners. But that's just me...
22RPD
TECHNIQUE
TRM
TECHNICA
RK
I don't want to talk bad about Rk specifically but do your research and find people who have owned each.. maybe try to contact the tuner and see they they reply :wink
1989 535i - sold
TRM
22RPD
Technique Tuning
Technica
AA
Jim Conforti
RK
1989 535i - sold
Yeah I'm trying to keep it above the subframe because it would make me worried to have the piping as the lowest point in the front. I already have the horns removed and the cold side piping doesn't seem like it will be too bad. On the hot side I was looking at this route around the A/C, I think it should work, I checked it out with the wheel at full lock too and it should have space to pop through around the side of the sway bar and above the steering rack and then its a pretty straight shot to the intercooler.
Okay Ill check them out, I have talked to RK and TRM before, Ill try contacting the others as well. Thanks
No love for just using RomRaider and tuning the sucker yourself?
That was my original plan, I have looked at RomRaider some but not too much. I decided to go with a company for the tune because I figured by the time I bought all the equipment and tuned it myself I would have spent more money than if I had just bought a good tune and I would have a mediocre if not poor tune. If you think that using RomRaider to teach myself is a viable option then I am all up for it.
I also have that extra engine in case I blow one up.
I can't seem to compose a reasonable post on my phone, so I will reply to this on Thursday when I'm back at my computer. The RomRaider option is very doable.
Also about the engine, do I need a different exhaust manifold gasket with the SPA since it isn't separated like the old headers and is it a necessity to replace the studs and nuts for the manifold?
1989 535i - sold
Do I need a new fuel pressure regulator for the amount of boost I'm running with 60# injectors and a walbro 255 fuel pump?
Sorry I'm a day late!
Anyway, RomRaider for MS41 DMEs is really well developed at this point, and makes it kind of a breeze to tune your own car. Or if you prefer, there are probably a lot of tuners out in the world who you could pay to tune your car for you, using RomRaider. It even has a very nice logger function, and with a little bit of hex code that is laid out pretty well in one of the threads, you can input your AFRs from your wideband's 0-5V analog output into one of your downstream O2 sensor signal wires so you can log that too. Pretty awesome stuff.
The recent fly in the ointment though, is that the guy who wrote and sold the DME flashing software has recently passed away. The software was/is phenomenal, in that it corrects checksums and makes reading and flashing partial or full reads super easy and automated. Since he has passed, the software is not for sale from his website I guess, so you can't purchase it there.
That leaves you with using Galletto for reading and flashing your tunes, and finding another solution for checksums, or maybe it's possible to use another person's purchased software until it might become available for sale again. I don't know. I do suspect though that there will be a solution to the problem pretty soon, since that flashing software was treated by the forum members as being necessary for use if you want any information from them.
By the way, I'm running E85 through 80# injectors and stock 1997 fuel system with the DME on RomRaider, and it runs excellent, year round in Michigan. It's hard to beat.
EDIT: I should say it's hard to beat on the cheap, and up to a certain level of performance. Certainly there are limits to its usefulness where a standalone becomes MUUUUCH better.
First off awesome information, I really appreciate the long and detailed post and if I could somehow do it I think it would be great cuz then I'll know how to do the tuning and I can always improve it if need be.
I was looking at the romraider site and was wondering if the software downloadable for windows on their front page is not the software you are talking about or if the guy who passed aways software is separate from that. I luckily I already have the Galleto tool though from when I was planning on tuning the car myself, I just need the adapter to convert it from the obd2 port the 20 pin connector port in the engine bay.
What does downloading the RomRaider 0.5.9 download give me and other than the ECU definitions, logger definitions, and car definitions they link to, what would I need to be able to tune it. Or is the software that is gone now one of those definitions. Again thank you for the detailed response, I will probably try downloading RomRaider and checking it out for the heck of it at the least.
The software to flash the tune into the DME is separate from the actual RomRaider software. It used to be $33 WELL SPENT, because it made the process so easy. It was at this link:
https://chipster.no/Siemens-MS41-Flash-Tool
As far as getting a good start on being able to use RomRaider for an M52/S52, here is a document that I wrote in hopes of easing a person into it:
https://sites.google.com/site/openms...with-romraider
It's still a lot of information, but I tried! Lol
Just a FYI, the turbo you chose is good for quick spool but the turbine match is horrible on low boost. I wouldn't expect over 300hp unless you have a larger AR or the gt35r. You'd need about 15psi to hit 330 hp. The higher boost you go the more efficient it will be for your setup
Oh okay, yeah I was a little worried about that, but I figured it would be okay, I guess not. I'm not too excited to try and sell mine and try and find another turbo although I have been reading about Borg Warner turbos like the s256sx but I figured something like that could be something to transition to in the future once I lowered compression. If people think that the turbo I have now would be very incapable on low boost then I'll probably change, but otherwise I'll probably just try and make it work for now. Thank you though, at least I won't be too let down if it doesn't get to 330 hp.
That was an awesome article and very informative, sucks that the software for flashing is gone though. I saw some other software out there like from flash.ecubin.com and I also found something at http://www.easysoft.pw/en/calc-gen-c...s41-flash-tool , but I don't know how legit those are.
I suspect there are easily attainable methods of flashing in tunes, I'm just not sure what the best option is currently.
Regarding your turbo choice, best to get running with whatever you have and then maybe try a different turbo later. Ironically, the turbo is usually one of the easier parts of the whole puzzle to play around with once you get the setup running and basically tuned.
