Bravo!
Most of this is going over my head, but I'm enjoying trying to figure it out!
Keep it up!
'95 540i/6
Swartz II
250K miles
'94 540iA
Island Green
178K miles
'99 E39 540i
190,000 miles
Since I would be retarding intake cams for such a late IVC angle. With the supercharger, I would be effectively running a Miller Cycle engine. I'm doing research now on the tuning and engine behaviors of running the engine this way.
e39 540i 6speed Supercharged,
E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
I've been fighting the crank bolts for a while. On both engines, I tried a breaker bar. Then breaker bar with jack handle as cheater pipe. Then I went and got an air compressor and tried my air gun. Then went and got a new air gun and a new 27mm impact socket.....Still no luck.
Loaded the engines into the back of my truck and took them down to a local shop. After spending 20mins of solid impact gun kicking on the M60B40 the crank bolt eventually backed out. No luck on the M62, we then tried to heat up the bolt with a propane torch and attack it with the impact gun. No luck. We then upgraded to a 1" drive two handed impact gun. Nope.
I've now left the M62 at another shop with the instructions to attack it by all means necessary, including oxy acetylene. This M62 has signs that timing guide let go and was replaced. I'm wondering if someone used locktight on the crankbolt and then impact gun to tighten.
I've made some more progress on the M60B40 tear down and now have the timing covers off. Where could I purchase new OEM M60B40 timing guides. They have signs of wear and grooves and would like to replace.
I kicked two crank bolt's asses with a Milwaukee 1/2 inch cordless impact. The M60 fought the hardest but it did submit after a solid ten seconds of blasting.
Bro, how did you get deck? You should not have a deck on m62.
Dial indicator zero'd on the deck. The M62 has .033"pop out, the M60B40 also is above deck but I haven't measured yet.
Standard is .025" above deck leading me to believe some had decked block before I got it.
Cleaned up deck surface and piston tops, installed head studs.
Still a long way to go, I only get a spare hour at a time here and there.
I see the oil feed port that needs to get blocked off when using the M60 double roller chain, idler & guides.
There you see difference of those waterholes. Bank 2 is smaller and that is reason why pistons 8 and 7 broke ringlands when you have more power.
I see it and plan to open up the smaller bank opening soon.
A friend wanted to see a rough mock up of the assembled engine. I was happy to oblige:
After tearing apart the M60B40 I've decided to order all new timing chain, guides, idler sprocket and crank gear. I've completely blown the budget out of the original mindset. This isn't an invitation to go for broke, I still need to mind dollars and cents. But I'll be able to sleep better at night knowing I've used some new parts in the build.
That M62 single chain crank gear did not come off peacefully:
After cleaning up the piston tops and deck surface I decided to check out piston to deck height again, this time using a proper cylinder bridge with the dial indicator.
Did you know that M62 pistons are dished? I didn't until I noticed I was getting different readings depending where on the piston top I was measuring from. I noticed as I would drag the cyl bridge from one side of the piston to the other following the path of the wrist pin the measurement would go down as it went to the center of piston and come back up going towards the edge.
The measured highest distant above deck, closest to edge of piston is .025" ABOVE deck. Middle of piston, .003" above deck.
I decided to use the same CC volume kit I used on the combustion chambers to get an idea of how much volume is in that piston dish. I brought the edge of the piston perfectly flush with the deck height and then filled her up:
I measured every piston with the cyl bridge and dial indicator and all came within .001"-.002" of each other. But I only CC'd one piston top and came to exactly 4cc's of volume in the piston dish.
I feel I've accumulated enough accurate information to now order head gaskets and move on with the project.
After crunching the above numbers with the new data, here is what I come up with as a good combination:
This would be using the 1.65mm thick head gasket, it brings the squish/quench down to .040" at the highest point of the piston edges. This calculated dynamic compression would be using O.E. cam timing with the M60 timing blocks...which I am now more inclined to do seeing that pistons are not as far above deck as I anticipated and taking into account that slight dish in the piston top.
Whoa, I LOVE this thread!! You are really getting into some cool details. Thanks for sharing!
Could not find 1.65mm thick gaskets anywhere, no online supplier. In the name of getting the ball rolling I ordered a set of Reinz 1.74mm MLS head gaskets.
New static compression: 9.78:1
New effective/ dynamic compression with boost and altitude: 11.41:1
.044" Quench/Squish.
I've spent the past couple of years learning all I could about the Bosch Motronic M3.3 EFI. Learned how to read the hex code, what to change. Experimented in tuning my 540i. Ordered every name brand performance chip to learn what and how other tuners changed and why. Worked with others to further the development of discovering all of the available possibilities of tuning the Motronic and I feel I've reached what I would consider my limit of wanting to work with this system. Frankly I'm just not getting the results and flexibility I want from an EFI. So I made a decision, go standalone.
The standalone of my choice? An open-source project called Speeduino.
An Aurduino based board that uses TunerStudioMS (Megasquirt) software for tuning. It allows for 4 injector controls and 4 ignition outputs. Which means my V8 will be in waste spark and two injectors will be paired for a semi-batch fire.
I've already gutted one DME for a retro-fit forthe Speeduino and two Bosch 4ch ignition control modules (Audi/VW) inside and then wire up to the original DME harness.
I program the unit to use the original crank sensor and trigger wheel (Bosch 60-2 with 60 degree offset) as well as cam sensor. Load a base tune, then TunerStudio has the ability to self tune the VE table based on desired AFRs. The Speeduino v0.4 board has a built in 0kpa-250kpa MAP sensor. It will be running Speed Density.
I am already sleeping better at night knowing that the commanded ignition timing and fueling from the software will be exactly what's happening in the cylinder. Unlike with the Bosch Motronic I had to hope the information available online is correct and use my best judgment. Even then, the vehicle performance was inconsistent. And without being to live stream sensor data, programming or datalog it really is a guessing game.
Wow! This is super-cool. I really like idea of re-using stock case and just rewire inside of the box so on outside it looks all stock. I guess you will need to get USB cable into the car, right?
How is I6 going to work with this ECU? 4 channels won't do, right? V8 have essentially 2x I4s, so it works..
I can see benefit on stock engine, it should work better just because it's newer and can adapt.
6cyl would just use 3 of the 4 channels of the injector and ign, you would have 2 paired of cylinders like the v8
I've decided the heads need a go through, a clean up, seat & valve dress up and new lifters.
I can officially disclaim; this is no longer a "budget build" but definitely can't spend the full amount or a total rebuild.
VERY interesting about your move to that standalone!
I recently went through the same thing with my car. The DME M5.2 just gave random, unpredictable results at times, and overall just freaked me out. Since I already had an MS3+MS3X partially built, I finished it up and installed it. Life has been heavenly since.
Does that Speeduino have coil driver transistors in it, or does it somehow integrate with the DME hardware?
Very cool, do you have a build thread?
The speeduino can not directly drive coils, instead I'm employing two Bosch ign modules that can drive 4 coils each.
http://www.useasydocs.com/Bosch_211.htm
I've also an MSD DIS-4 but I'm hesitant to use it as it would need to drive 2 coils per channel.
