Results 1 to 7 of 7
Thread: 2.5 z3 to 2.8
    Sep 2017
    Fayetteville nc
    Z3
    2.5 z3 to 2.8
    I have a 2000 z3 with a 2.5 and yesterday the engine blew.. only 135k but I've found a 2.8 for 500.. my question will it plug and play like the 2.5? Winter time I will be putting my ls1 in. Also I got an m5 rear end with the car will it fit for my ls swap? Otherwise I'm going to use a ctsv rear
    Aug 2016
    Spring TX, USA
    2000 BMW Z3 2.3
    M5 and CTSV rear will not fit without seriously major modification. We would be talking custom rear subframe modifications, new custom driveshaft, custom halfshafts etc..
    I have the same car that you do.
    The stock 3.15 (if you have a manual, auto is 3.46 i believe) 188mm Torsen LSD is sufficient to handle the rated power of an ls1. I rebuilt a 53k mile diff I bought to replace my worn out squealing one.
    That said, if you are wanting to part with your m5 diff, I may be interested for projects later down the road.
    Jul 2004
    Houston, TX
    36 Cylinders
    You should flash the ecu to 2.8 for correct operation. Otherwise plug and play.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Sep 2017
    Fayetteville nc
    Z3
    I'm in North Carolina if your interested pm me your number and I'll send you pics
    Quote Originally Posted by TommyMaddox View Post
    Sep 2017
    Fayetteville nc
    Z3
    Also found a 3.0 will it fall right in? And mate to the 5speed? Or is it a lot of work?
    Jul 2010
    San Francisco
    03 530i/5, e30 s52(Sold)
    Quote Originally Posted by Fayettevillin View Post
    Wiring, and ecu will definitely be harder since the 3.0(m54) is a completely different motor then the 2.8(m52). To save time and money I would just go with the 2.8 especially since it's only temporary until you put the ls1 in.
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Check your VIN Decode to see which 2.5 L engine you have, so you know your starting point. You are at the cut over point between the M52TUB25 and the M54B25. Both these engines are duel VANOS. This means that you need a Duel VANOS engine to swap in.
    Options are:
    - M52TUB25, straight swap
    - M54B25, straight swap
    - M52TUB28, flash DME for this engine
    - M54B30, flash DME for this engine
    Note: a M52B28 single VANOS engine will not work for you.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
  1. Wheels from a Z3 to an E36 M3?
    By ///M_Drift in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-14-2004, 09:02 AM
  2. So I drove my Z3 to work this morning...
    By Numanoid in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-25-2004, 01:01 PM
  3. anyone move from a Z3 to a s2k or vice versa?
    By Ridgeway in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-09-2004, 09:48 AM
  4. Z3 to M3 clutch conversion?
    By AmZdriver in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-23-2003, 05:58 PM
