Results 1 to 22 of 22
Thread: QUESTION: E36 AA Twinscrew Accelerator Cable Spec?
    Feb 2010
    Rochester, Michigan
    E36 M3
    The AA Kit used OEM parts for some cables and hoses in their kit. For example, the upper radiator hose should be from a 1995 540i, which has a bump to clear the S/C pully. The accelerator cable I think I remember remembering was from an earlier 3-series, but I can't find my notes or any threads expressing specifically which cable to search. 1995 M3 sounds familiar, but so does E30 325i.
    My cable has been bent since I received the kit (used), but I managed to massage it back to being usable. Now it is getting sticky probably from wear along the crease. It is about time I get a new one.
    Does anyone know which cable I need?
    Pic for attention:
    Apr 2013
    Alabama
    1995 M3 Coupe
    No idea, hit up craig wong at AA. He's been pretty responsive to help me with any questions about parts with the twin screw kit.
    1995 M3...Screwed
    Kirkland, WA
    98 M3 Twinscrew, 07 X3
    Feb 2010
    Rochester, Michigan
    E36 M3
    Thank you, Alpine! I can't count how many times I have failed to find that thread. Subscribed to it now
    But I still can't find the throttle cable spec
    Quote Originally Posted by Alpine 318is View Post
    Feb 2001
    Gallatin, TN
    97 M3/4 - Hurtig/AA TS
    My records (and I designed it, so hopefully they are correct!) are that it was/is an E34 540i throttle cable. I don't seem to have part number handy, but that is what I can find.
    Have you been Screwed?
    air, dirt, fire, water
    95M3 92525iT 78810 95525
    A rare sighting.
    Feb 2001
    Gallatin, TN
    Quote Originally Posted by milKt View Post
    A rare sighting.
    Been getting ready to fiddle with my car again since it needs some TLC/Refresh. Also preparing a manual swap into a 1998 M3/4/A that I recently bought my son who just started college and signed up here as stimpeejr (who was born about 2 years before I started the TS work!). So I have been poking around a bit again. I think most of the wounds are healed now...
    Welcome back.
    Scars are just God's little smiles.
    Feb 2010
    Rochester, Michigan
    E36 M3
    Quote Originally Posted by stimpee View Post
    Gentlemen, I ordered a 90’s 540i throttle cable, the parts guy gave me this part number. My original cable could be incorrect since I got the kit used, but it looks like we need a 90 degree bend at the throttle body side for it to fit. I’ll head back to the dealer to see if they can help find a better option.
    P/N: 35 41 1 161 881
    Tanks95's Avatar
    Tanks95 is offline M3s Only Have Two Doors BMW CCA Member
    Nov 2002
    North Carolina
    I6 & V8 ///M
    hmmm, i dont have the AA kit, but i know the ES TS kit did not come with a different throttle cable, and i am about 95% confident that my OEM 95 M throttle cable has a 90 degree bend. ill check this evening after work.
    In the mean time ill see if i can access my flickr account from work....
    If your M3 doesn’t have 3 pedals and 2 doors, I would really consider contacting BMW to confirm the authenticity of your incorrectly badged mid-sized family sedan.
    Tanks95's Avatar
    Nov 2002
    North Carolina
    I6 & V8 ///M
    bingo! Found a pic in some old pics of my car.
    Two views, but its clearly a 90 degree.
    https://www.flickr.com/photos/wt_wallace/6114776138/
    https://www.flickr.com/photos/wt_wal...n/photostream/
    SW Florida
    99-01 M Cpe & Rdts, X5M
    I have the ES installation instructions, and there was no mention of a different cable required; the AA setup was only marginally different (plenum shape/TB location). Put it this way, I've always used the car's original/OE replacement throttle cables.
    Tanks95's Avatar
    Nov 2002
    North Carolina
    I6 & V8 ///M
    Quote Originally Posted by Randy Forbes View Post
    ^^ yes...
    Feb 2010
    Rochester, Michigan
    E36 M3
    Thank you for the investigation and updates, gentlemen! I really appreciate it.
    I looked through my "box-o-parts" and did not find my original thottle cable. For some reason I believe the one supplied with the kit was longer? Is there a difference between the length of the E36 OBD1 vs. OBD2 throttle cables?
    Feb 2010
    Rochester, Michigan
    E36 M3
    Gentlemen, I tried the E36 cables, they will not work. While they do have the correct 90° bend at the t-body, they are about a foot too short to reach the t-body. Both the OBD1 and OBD2 cables are identical (although have different part numbers).
    I found an E34 M50 cable p/n: 35-41-1-160-609 which looks similar to E36M3, but I cannot find length specs.
    6/29/18 updated with pics
    http://i485.photobucket.com/albums/r...psqspfgodp.jpg">
    http://i485.photobucket.com/albums/r...psklcbkznw.jpg">
    Jan 2006
    Oakhurst, CA
    96 M3, 98 M3
    E36 and E34 M50 are pretty significant in length just looking at the pics.
    E36 35411163228 https://www.ecstuning.com/b-genuine-...e/35411163228/
    E34 M50 35411160611 https://www.ecstuning.com/b-genuine-...e/35411160611/
    NLA though...
    Feb 2010
    Rochester, Michigan
    E36 M3
    Quote Originally Posted by Braymond141 View Post
    NLA though...
    That E36 one looks identical to the E36 one I mentioned above, it is about a foot long. The second one, that Bowden cable, has the ends reversed, at least in that picture. I'll search for that e34 one and see if I can get a better picture of it. It looks like, if the ends were correct, the length would be enough.
    Feb 2010
    Rochester, Michigan
    E36 M3
    I found a longer version similar to the "bowden cable" but with what looks to have correct ends. 35 41 1 164 636 Supposedly for a RHD version. I don't think it matters.
    I found it on ebay international, getting it from Latvia (fingers crossed)...
    Feb 2001
    Gallatin, TN
    Let me try to "mine" my old records again and see if I can find something as specific as a part number or more info.
    Active may be able to point you in the right direction as well, but not sure...
    Feb 2001
    Gallatin, TN
    Ok, found this pretty quickly:
    35 41 1 164 636 from RHD 328 obd2
    Looks like they are still available, and looks right from the pictures.
    We should probably get this into the "parts" thread...
    Steve
    Feb 2010
    Rochester, Michigan
    E36 M3
    Steve
    Right on!! That is the same number I found too. For some reason I could not find it state-side.
    I second adding this to the sticky
    I'll post up some pictures and stuff once I get the cable and install and confirm.
    Feb 2001
    Gallatin, TN
    Shows as available here, although I have not tried to actually check out with it...
    https://www.getbmwparts.com/oem-part...0d-35411164636
  1. E36 E36 Accelerator Cable: S52, M52, others
    By wanganstyle in forum Engines, Performance Parts & Software
    Last Post: 10-31-2011, 03:32 AM
  2. Active Autowerke AA Twinscrew for E36/S52
    By susan28 in forum Forced & Chemical Induction Parts
    Last Post: 05-20-2011, 02:48 AM
  3. Question About AA TWINSCREW pulley.
    By M3roar in forum Forced Induction
    Last Post: 07-24-2009, 02:29 AM
  4. Question about AA E36 kit - MAF wires
    By TouringDan in forum Forced Induction
    Last Post: 06-07-2009, 09:16 AM
  5. WTB: e36 M50 Accelerator Cable
    By Xenocide in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 03-14-2009, 07:20 PM
