Is it possible to connect an OEM radio to an aftermarket AMP?
My fiend wants to keep everything absolutely stock in the interior, so we need to re install OEM radio, however he has Sony radio in there with OEM amp missing.
Don't see whey not, I have them in my primitive cars with stock radio cassettes along with MP3 changers and USB ports to handle MP3 files. How will your friend justify upping the amp with crummy speakers?
You need an amp that takes High-Level (speaker level) inputs though, as the factory head units do not have Line-Level (RCA jacks) outputs
The OEM amplifier is an oddball that way, it takes the high level input... most aftermarkets are setup for line level. High-Level into an amp that is designed for Line-Level = disaster
Also, if you do use an aftermarket amp, you're losing all the crossovers in the system, as that is part of the OEM amp.
Not sure how it is wired up now, but if he really wants the OEM head unit, putting the OEM amp back in too might be the best approach
'91 850i 6sp (mint) (sold)
Agree 100%
If your friend needs the stock HU, it will be cheaper and easier to pick up an OEM amp and pop it back in. (Assuming that the PO didn't hack the wiring harness)
Trying to use an aftermarket amp with the stock radio can certainly be done, but will take a bit of work and might even sound worse.
I have also heard that you can use the Harman Kardon Top Hi Fi amp from an e36. Supposed to be same connections but an amp upgrade. I believe Olin has it installed in his 94 840.
It's is not the amp that will make the difference..... speakers will and these are rubbish. I have done one, converted everything: head, amps, speakers (keeping stock looks) and still my lexus sound system was way better. So back to stock and always off.
You just do not have enough space and volume for speakers and cabinets in these cars unless you start modifying everything.
Would suggest: headphones on your phone.......
BMW 850 CSI march 1994 (EU spec), SOLD. https://www.classiccars-forsale.com/...94-bmw-850csi/
BMW 850 CSI november 1994 (EU spec)
Thank's guys, currently OEM amp is missing and no stock head unit. I have both, sounds like it make sense just to reinstall both OEM components as he is just after the OEM look.
Assuming you could get an amp that takes speaker level inputs (or use aftermarket unit with line level inputs), how would you connect the amp's speaker outputs (and aftermarket crossovers) to the factory harness? Will individual standard single-pole female connectors work for each connection, or is there an aftermarket amplifier cable available?
