Results 1 to 9 of 9
Thread: M50b2x VAG coils conversion in progress/ MS2 (kDFi)
    Jul 2013
    Brno, Czech Republic
    e34 m50b25 turbo
    Lightbulb M50b2x VAG coils conversion in progress/ MS2 (kDFi)
    Hello, i would like to share with you guys, my upgrade from stock m50b25 coils to 4pin logic - VAG/Audi R8 coils. I´ve been trying to solve my ignition problems ( missfires under boost) million different ways, but nothing did not really help. So i decided to try VAG coils which should give stronger spark with less noise due to build-in ignitor.
    Engine management is MS2 (kDFi), modded to sequentional ignition (COP).
    So first I´ve bought Audi R8 coils. I´ve been told they fit on m50 valve cover without any mods. (Beru ZSE032, OEM : 06E 905 115) and piggytails from aliexpress for few $.
    First I´ve cut old piggytails and found out that the stock m50 ignition wiring thickness is really insufficient in comparsion of AUDI stock wires. Here is the picture of OLD and NEW connectors and wirings:
    Here is the photo of coils and how they sit on the valvecover. And the mess in wires.
    21390664_10207934956972228_1541224458_o.jpg21362371_10207935217178733_1807407355_o.jpg
    After I finished the wiring of the coils, according to wiring schema of a logic coil, I though that it will be ok to only desolder stock IGBTs and jumper them (run MS2 spark signal output straight to the signal pin of the each coils). But then I double checked the MS2 manual and found out, that I need to add some buffer circuit, with the TC4427s and 15R rezistors.
    Now im waiting for delivery of the TC4427s and maybe tommorow i will continue with it. Im very curious if this will help me.
    Nov 2011
    canada
    2004 E46 M3 Cab
    Is this circuit needed because ms ems has built in igniters ?
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by being3 View Post
    An MS2 needs a transistor added between the processor and the coil. The processor cannot handle the current load to switch the coil directly. An MS3x or MS3pro already has this built in.
    Jul 2013
    e34 m50b25 turbo
    So i made the circuit with TC4427s and connect between the processor and the coil pins, checked everything and tried to start the car. Car started easily but only on 5 cylinders. 5th cylinder was not firing. So i´ve checked and resolder pins leading to the 5th coil (which should be spark b output from the processor)
    My tacho stopped working aswell. Ive tried to switch from Coil on plug to Wasted COP but it run even worse.
    Any ideas what to check or try??
    Edit: Now its running on all 6. There was bad contact in one pin of MS processor. After i clean and secure the wirings i will go to test, if it still misfires.
    Jul 2013
    e34 m50b25 turbo
    Tested. No more missfires. After a whole day of drifting, not even a sign of misfire!! I´m so happy.
    Feb 2017
    New Zealand
    318is
    Reviving an old thread here, was this KDFI v1.4? This video shows wiring of AEM coils and no buffer was needed to run them? how come he didn't need to?
    https://youtu.be/WTlu0SQXsx8?t=12m32s
    Jul 2019
    katy.tx
    2007 bmw 335i
    any updates
    Nov 2020
    Delaware
    E36 328is
    Wiring
    Do you by chance of how to wire in the pigtails to the factory harness and what does the 4th pin need to be hooked up to on the audi coils? I’m hoping these can be run off the factory ecu thanks for the help
    Jun 2016
    The Netherlands
    1991 325i e36 Sedan
    Factory ECU won't run these coils, M5x coils are switched by ground signal from the factory ECU through the use of ignition-capable IGBTs.
    VAG coils are signaled with +5v logic level signals, you can't run them without modding your ECU.
  1. OBDI Conversion In Progress - Specific Questions
    By ///M3///M5 in forum Forced Induction
    Last Post: 04-24-2007, 05:04 PM
  2. OBDI Conversion In Progress - Specific Questions
    By ///M3///M5 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-24-2007, 09:48 AM
  3. AUTOX in Converse, IN
    By Matthew C Smith in forum Great Lakes - US
    Last Post: 10-23-2002, 04:10 PM
  4. Water/ Alcohol install in progress
    By BP SCM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-21-2002, 04:19 PM
  5. How about an E46 M3 3.2L w/ OBD-I conversion in a '95 E36?
    By trackm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-19-2001, 04:47 PM
