Results 1 to 9 of 9
Thread: 750il and 850i parts interchangeable
    Sep 2017
    Ontario
    1991 BMW 850I E31
    Are the pulse sensor on spark plug wires 6 and 12 iterchangeable? Aswell as the crank sensors on the timing cases? The Pulse and crank sensors show up in alot of parts databases for the 750il but not under the 850i.
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Yes they are.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    easy to check which parts are interchangeable, find the part number for your car on realoem, copy and go back to realoem and paste the number under PART NR APPLICATION SEARCH and all BMW using the same number will be shown
    http://www.realoem.com/bmw/select.do
    Sep 2017
    Ontario
    1991 BMW 850I E31
    Thanks, and good tip for future searches, I don't think straight when my car doesn't run properly.
    Bay Area, CA
    Not a Ferrari
    The sensors are interchangeable, but the spark plug wire looms aren't. No problem if you're just taking the sensors, but if you're trying to use wires from a 7 the plastic wire looms don't exactly bolt up easily from what I remember.
    1995 540i/6 // Dylan Leff - www.originalplate.com
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Quote Originally Posted by mojocoggo View Post
    Not quite correct - the wires from an E32 750iL will match up to the M70 engine in a 1991-1993 E31 850. The same goes for the M73, they are interchangeable. I have wires from my M70 on our E38 (M73) - no problems
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    NY, NY
    84 633, 91 M5, 91 850
    Bumping this thread- I'm in need of wires, and the E32 sets are easier to come by than E31. Is the difference in the plastic carrier only, or perhaps the wire lengths? I noticed they are different part #'s on RealOEM from E31 to E32. My 850i is a '91.
    Nov 2013
    Whitney, TX
    97 850CI
    Shogun sells wires. I highly recommend you check his out.
    Desecrator of all things Sacred
    Jan 2005
    Japan
    The differences
    E32 750
    IGNITION WIRING TUBE 2 up to 02/1990 12121715824
    IGNITION WIRING TUBE 2 from 02/1990 12121729305
    IGNITION WIRE X 12121705675 all production years
    Reason: up to 02/1990 pre facelift engine with oil filler cap in the valve cover at the rear, facelift has it at the front. Wiring tubes have the fixing points and the outlet holes for the ignition wires in different places.
    E31 850Ci all years
    IGNITION WIRING TUBE 2 12121729305
    E31 850CSi all years
    E38 750 M73 all years
    I offer the ignition wires only and that is why they fit on all M70 and M73. But the old ignition wiring tubes have to be used and the donuts/cylinder identification sensors have to be transfered to my new ignition wires which have woodscrew type connection on the angled boots.
  1. Difference between 750il and 850i spark plug wires?
    By dragon850 in forum 8 Series (E31)
    Last Post: 12-24-2014, 10:30 PM
  2. 2000 528i and 540i parts interchange? -Fender Bender-
    By beachbimmer1230 in forum 1996 - 2003 (E39)
    Last Post: 11-18-2014, 11:54 AM
  3. Interesting info on MZ3 shift lever into Z3 and parts interchange
    By Herbie in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-23-2008, 09:46 AM
  4. Are Coupe and Sedan suspension parts interchangable?
    By Ianbiz in forum 1999 - 2006 (E46)
    Last Post: 06-27-2007, 12:09 AM
  5. Open and LSD parts interchangeable?
    By black318i in forum 1991 - 1999 (E36)
    Last Post: 12-10-2004, 07:02 PM
