Page 8 of 12 FirstFirst 123456789101112 LastLast
Results 176 to 200 of 282
Thread: Airbag Control Module, Internal Error (F0, 240 errors). Finally found a fix!
  1. #176
    Sep 2003
    Decatur, IL
    88 325, 91 325ix, 95 M3
    Hey guys. Not a Z3 but a similar module in my e46 1999 323i. I had the airbags unplugged when doing door panels and got everything buttoned back up. Now, I am getting a one fault from the SRS system "internal control unit fault" Don't remember the number. But, that is the only error I am getting. Sounds like my SRS module may have gotten one of the permanent faults?
    Oh, one other thing. While I was driving the car I was checking codes and I noticed that it did not even find the SRS module during one scan...found that odd. Definitely made me think the module is on the fritz.
    - Sean Hayes
    Illini Chapter Driving Events Chair
  2. #177
    Jul 2004
    Houston, TX
    36 Cylinders
    I would question why it didn't trigger side airbag faults. Due to the abundant availability of E46 modules and that your module only has the one single error, I would consider finding a spare used one. It may be recoverable, but if you can find a good used one that you can code in, it may be a slightly better option. For Z3, this isn't an easy option. There just aren't too many around.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  3. #178
    Sep 2003
    Decatur, IL
    Thanks Abel. I found the same PN on ebay for $30. But, the SRS module needs to be programmed then? I have NCS expert but no idea how to use it. lol
    - Sean Hayes
  4. #179
    Feb 2018
    GREECE THESSALONIKI
    BMW 335 E92
    hello abel can you help me?
  5. #180
    IL
    2000 740i sport
    Thank you for this information. I am using this information at an attempt to revive my 6900727 airbag module How are you reading and clearing the errors using tool32 on the bench? I'd like to make sure I can clear all errors before reinstalling the module in my car.
  6. #181
    Feb 2020
    Austin, TX, USA
    2001 BMW 530i Sport
    Hey!! I am having the same issue in a 2000 740iL. Would you consider fixing it for me. I'm happy to pay you for your time.
  7. #182
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by ffarrera View Post
    Send me a PM with your email for contact. I would want to make sure your module isn't failing internally, so a listing of the codes and how many times they have happened helps. If there is a problem with the module itself, or the original offending issue persists, the error will come back.
    -Abel
  8. #183
    May 2022
    Atlanta
    2000 BMW Z3 M
    Hey Abel, I don't see the option to PM you (may be due to me being new to forum). I need help with 2000 Z3M airbag module showing 3 errors: MRS: (16) Sensor for side airbag left, (F0) Internal control unit fault, (11) Power Supply. Please try to send me PM with info to ship the module to you. Thanks.
  9. #184
    Jul 2004
    Houston, TX
    36 Cylinders
    I can't PM you either, you're too new here.
    If you want, post your email address here, and I can tell you when to edit and delete the email address.
    -Abel
  10. #185
    May 2022
    Atlanta
    2000 BMW Z3 M
    Thank you.
  11. #186
    Aug 2021
    Austin Texas
    2002 Z3, 2000 Z3 M
    Okay, need a little more help to clear some gremlins.
    I was able to re-install the SRS module after Abel reset it. I got a code for the driver side under seat side airbag module and replaced it. Cleared the code automatically and no light = yay!
    Now I am getting an intermittent light that comes and goes as I drive. The B800 tool throws codes 15, 16, & 17 from table 40. These seem unlikely to be related to the recent replacement of the side module. Any experience with these?
    (15) Seat belt buckle switch, passenger
    (16) Satellite, left sensor (for side airbag), comms fault or open circuit
    (17) Satellite, right sensor (for side airbag), comms fault or open circuit
    My next step is to try to clear the codes in case they are residual from previous attempts to find the error.
  12. #187
    Jun 2022
    Vancouver Wa
    E39, e28, e30, e36
    Do you still program the module for e39 srs?
  13. #188
    Aug 2021
    Austin Texas
    2002 Z3, 2000 Z3 M
    Bump. if anyone can advise.
  14. #189
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by John Wick View Post
    The seat belt buckle switch is what sometimes causes an intermittent light, but more of a 5 second light at startup.
    You can attempt clearing the errors, but the left and right sensor errors are concerning. It needs further diagnosis with better tools.
    -Abel
  15. #190
    Jun 2022
    Maine
    00 528i
    This thread has been super helpful for me. I also have these issues going on and am hoping I can have you Abel help me also. I’ll post later my cars info and what not. Thanks!
  16. #191
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by yetimeister528 View Post
    Quote Originally Posted by Enut View Post
    I still repair these here and there as I can, even for E39. But keep in mind that the original issue MUST be fixed first. It's often something else in the system that triggers the internal fault.
    -Abel
  17. #192
    Jul 2022
    Woodbridge, Va.
    2001 BMW Z3 3.0i Rdstr
    Mine just took a dump, could really use some help. I have module out, only code in it is the F0 MRS: Internal Control Unit Fault… Failure to wait before disconnecting neg cable. Can you fix per your post part #65776908896
    For a 2001 BMW Z3 Roadster 3.0i, my daily driver… need to pass inspection, out of work 😢 If you’re still fixing these I would overnight it to you.
  18. #193
    Jul 2004
    Houston, TX
    36 Cylinders
    I still fix them here and there, PM me on the forum with your email and I can give you more details.
    -Abel
  19. #194
    Jul 2022
    Woodbridge, Va.
    Can’t PM- too new
    Bought a 2nd unit used so have one Id like to send to you… to fix. I’m under the impression I should be able to bolt this one I have coming in and then scan it to see what codes are in it. Just hoping not to see the F0. It’s the same 8896 module so shouldn’t need no programming unless it has crash data. I’ll repost in a few days. Can you PM with infor on sending you one to fix.
    There are no other codes other than F0
  20. #195
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by dauberman1 View Post
    It will need programming/coding with NCS Expert. It will carry the VIN from the donor car. The part number isn't what determines the programming inside.
    -Abel
  21. #196
    Jul 2022
    naples, florida
    2006 330I sedan
    I have a Z3 module that is making errors for both "sensor for side air bag" 16 022 and 07 023. We replaced the sensor (they were under water and corroded badly) and still have same faults. We attempted to code the module - but there is an error for module not for vehicle it is installed in, the VIN in module does not match the car according to Autologic. They have recommended I replace the module with one ending in 896 (mine ends in 192) but I am concerned if I buy a used module, it will have a VIN in it too and I will not be able to use it. If i buy a used module, can you virginize it, or can you do something with mine?
    Thank You
  22. #197
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by nplze90 View Post
    Thank You
    As long as you don't have F0 (internal error): It needs to be coded with the BMW tools, such as NCS Expert. That will update the VIN automatically.
    I included instructions for all of that here https://www.bimmerforums.com/forum/s...xperimentation in post 1
    -Abel
  23. #198
    Aug 2022
    Canada
    2001 740M, 540, 2000 528
    Hi,
    I have been driving a 2000 528 with the F0 internal ecu error for years. Recently a friend of mine bought also a 2000 528 exhibiting the exact same problem. Error F0 with the control module rejecting the clear command from INPA.
    I have decided to fix the airbags on both cars and would need help with the removal of that fault code.
    Can I contact you somehow Abel? I cannot message you directly.
    Jul 2004
    Houston, TX
    36 Cylinders
    Private Message should* work fine, going by the amounts of PM I have received even by users with 0 posts.
    Otherwise you may have to provide your email address here and erase it afterwards.
    -Abel
  25. #200
    Jul 2004
    Houston, TX
    36 Cylinders
    Sent an email, you can edit the previous post to remove your email now.
    -Abel
  1. F/S AIRBAG CONTROL MODULE & SIDE BAGS MODULES FROM A 98 M3
    By Corra in forum Exterior Lighting & Body Parts
    Last Post: 09-06-2012, 03:14 AM
  2. thinking about sending airbag control module out
    By KUSA325is in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-08-2009, 08:17 AM
  3. Airbag control module
    By matt325ibmw in forum 8 Series (E31)
    Last Post: 06-20-2008, 03:55 PM
  4. F/s Airbag Control Module & Side Bags Modules From A 98 M3
    Last Post: 02-08-2008, 02:49 PM
  5. Airbag Control Module
    By havnfun328 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-29-2007, 02:37 PM
